Sent email appears as if it was forwarded?
  • oldtech
    • 83
    Received email appears as if it was forwarded? Customer has to open twice to get to the actual attached file.
    KMC284e
    Is there something in setup I missed? We did point it to a ldap server which works fine. I feel like its something simple I'm missing. I searched here but only found one post with the same question with no reply.
    Any help is greatly appreciated.
  • NeoMatrix
    Senior Tech.
    • 3513
    Re: Sent email appears as if it was forwarded?
    Are you referring to Email/Fax forwarding when an email/fax arrives to the MFD and then forward to a workstation ?
    • oldtech
      • 83
      No, user scan to email. We set it up just like many others, I wonder if its setting on their mail server, its in a bank. We installed a Ricoh unit as well (demo) and have heard no complaint from that one yet. That one went in a different dept but used same settings except different ldap search string.
      Thanks for looking
      • habik
        • 2013
        Have you tried firmware update?
        Sent from my iDon't believe in marketing device using Tapatalk
        Firmwares HERE
        • oldtech
          • 83
          It should have the latest firm, our shop policy is to push latest firmware before they go out. BUT I did not check it on site. I'll add that to the list for when I go back after the holiday. I have mail server set up on my laptop so I can run test without their mail server.
          Thanks for the firmware reminder.
          • Mr Spock
            Vulcan Inventor of Death
            • Aug 2006
            • 2064
            If they are using outlook then it is an outlook issue. I had an IT guy look into it and told me he fixed it but did not tell me what it was.
              • 30253
              Let it go, just know it was an Outlook issue.
              Best guess is that the outlook sender email was also forwarding
