Canon iR3300 Network Connectivity
  • ss200222
    • Jan 2012
    • 21
    Hi
    New to this forum, i have a Canon iR3300, can any one please guide me with setting up my copier with my windows 7 pc?
    Ragards
    Re: Canon iR3300 Network Connectivity
    Originally posted by ss200222
    Hi
    Ragards
    what are you wanting to setup? Print? Scan? email ... more info .. what print driver are you using?
    once you have your PC connected to the unit you should be able to set all those functions up via RUI
      • 8132
      Hi
      Ragards
      Firstly this old model didnt always come with the print option.
      Does yours have a LAN/Network port?
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Plus it has to be an "i" model in order to push scan.
        A 3300 vs a 3300i.
        And, no, there was no way to convert from one to the other.
        TWAIN, or "pull" scanning, would work if not an "i" model, with Network ScanGear and an application that could scan.
        • ss200222
          • Jan 2012
          • 21
          Only Print & Scan via PC...and what's RUI??
          • ss200222
            • Jan 2012
            • 21
            Yes it has LAN / Network Port!!
            • zoraldinho
              teacher-guide-expert-guru
              • Mar 2008
              • 5007
              Only for model IR 3300i
              IR 3300 >network settings>turn DHCP to ON
              Connect IR 3300 to lan network
              Restart machine,find IP number and Write it down then turn of DHCP
              Download and install driver on your computer.
              Download link
              On this Canon site you can find necessary software.
              If you have problems with network installing you can help with NetSpot Device Installer
              Scan software:
              Network ScanGear
              Click on "understand the risk" for redirecting!
              Good luck!
                Remote User Interface..
                in your browser type in the IP address for the machine... you will then be looking at the machine config ect.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  An iR3300 "non "i" can print IF there it has the print option.
                  If I remember, there will still be a network port if there is no print option. IP settings (including DHCP) will still be there.
                  While there are a bunch of ways to see if printing is installed, one is to check for the presence of NetWare and Appletalk in the network settings. If missing, it's doubtful that printing is there.
                  Also, check the version of the Boot ROM. If it's an "N", printing is there. If it is a "C", no.
                  I've been out of Canon for a long time now, but I don't think that ever changed, especially on this old relic.
                  • ss200222
                    • Jan 2012
                    • 21
                    Got it, RUI, but the printer still wont print anything, how to set SYSTEM MANAGER INFORMATION??
                    • zoraldinho
                      • Mar 2008
                      • 5007
                      Did you check bootrom version?
                        did you set the IP address to match the unit? have you pinged the machine IP address and got back positive replies? do you have the print driver installed for the unit and set to the proper IP address?
                        really need more info to help you.
                        • saabirshaikh
                          I have two Drivers pcl5e_5c & pcl6
                          Am running Windows 7 / 64 bits.
                          Ping does not return any reply.
                            • 29936
