Excel, any experts here?
  • Hansoon
    • Sep 2007
    • 3367
    Customer wants to work on Excel sheets with 2-3 parties at the same time. Is that possible? Does it need a server environment or would it work somehow with workstations connected through peer-peer?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
    • 8131
    Re: Excel, any experts here?
    Hans
    There is a Microsoft forum similar to this copier one, you may get more advice on there.
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      This may help.
      Excel shared workbook: How to share Excel file for multiple users
      • rthonpm
        • Aug 2007
        • 2847
        The easiest way to do this is with co-authoring. Share the file with anyone who needs access to it, and you can collaborate in real time. The only restriction is you need Office 365 for this to work.
        Collaborate on Excel workbooks at the same time with co-authoring - Office Support
        Last edited by rthonpm; 01-27-2019, 09:34 PM. Reason: Added link and clarification
        • tsbservice
          Field tech
          • 7963
          We used to use shared Excel workbooks where several people do almost simultaneously changes in the book and it will works most of the times.
          • 907tec
            • 434
            We do this with Google Drive / Google Sheets all day long. Works great. Not sure if that is an option for your situation, but Sheets can do almost everything that Excel can (for free).
            • dudeman
              • Feb 2019
              • 7
              yep, google drive sheets will solve this problem or you can use Sharepoint...but that is more complicated
              • Bix
                • Apr 2018
                • 1421
                Google Drive is the best solution.
                Free (15GB), secure and save in the cloud.
                If they want infinite space, they can buy it.
                • dudeman
                  • Feb 2019
                  • 7
                  And I failed to mention, Xerox, Ricoh/Lanier & Kyocera have an app that connects directly to Google drive so you can scan right into your account from the device. Xerox and Lanier/Ricoh does not allow their operation panels to store credentials, so everytime you access your account you have to log in, which is cumbersome. Kyocera however does so you can access your account much easier. Users hate having to log in every single time.
