Canon IR 3025 Won't print will ping (Port 9100 shows closed)
  • Doug James
    • Jan 2012
    • 935
    This copier was givin to the customer. It works fine copying. The IT guy went to get it on the network and he says that Port 9100 shows closed. He thinks that setting it back to factory defaults or "DCON Clear" might work. It will ping successfully and shows the web page. Shows "error" when trying to print to it. Any help will be very appreciated..
    • 23006
    Re: Canon IR 3025 Won't print will ping (Port 9100 shows closed)
    Is it even capable of printing? Just because it has a network port does not mean it has a print option installed. =^..^=
    • Doug James
      • Jan 2012
      • 935
      I thought if the Ethernet was on it that the kit was installed. ? (This is what happens when the copier tech is very unfamiliar with networking... lol)
        • 23006
        Canons of this time period came from the factory built with the desired options, and could not be added to. So for example, the outside of each of these models looks the same, but it it had a print option it got a different controller board than if it didn't. Somewhere in there you can print a list of the options installed.
        • copier tech
          • 8138
          Press the 123 button (counter) from that screen you can see if the kit is installed, look for anything that says "printer kit"
          Yes daft Canon used to sell print as an "optional" extra laughable today!
          Also if the model number IR 3025 on front panel doesn't have 'N' after at the end the kit was not installed at factory.
          • Ceechtay
            • Sep 2011
            • 157
            If port 9100 is closed, that is for RAW printing. Have they tried printing via LPR (port 515)? You can change that by configuring the Port in the Port tab of Printer Properties on Windows.
            They could also try IPP as well.
            • guitar9199
              • Sep 2016
              • 1100
              Most likely that machine doesn't have PCL/PostScript installed. Try again with UFR II drivers, and see if it prints.
