Can't connect
  • kingarthur
    • 1350
    Can't connect
    Just installed 2 new KM Bizhubs, all except 1 PC can connect to print, it's a Windows 7 upgraded to Windows 10, if you input the IP for the C3350i to the internet it can't connect via the pagescope, but other PCs can, however it can connect to the C250i via pagescope, trying to set up to print to the C3350i but it won't as it can't see the printer, yet the other PCs in that location can..... weirdest problem I've ever seen, escalated to the customers IT, but have had problems with their IT before, so am trying to assist our customer, has anyone seen anything like this before.
  • qbert69
    • Mar 2013
    • 1152
    Re: Can't connect
    Check network location to see if it's set to public or private. Also see if there are any pending updates to be installed. I have known scanning not to work until updates were completed. [emoji41][emoji1303]
    Sent from my SM-N950U1 using Tapatalk
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
      • 30159
      Re: Can't connect
      Get with there IT , too much information missing here to give you an answer.
      • tsbservice
        Field tech
        • 8007
        Re: Can't connect
        If you ping C3350i from problem PC what happens? I have seen bad network cables/ports dropping connections intermittently,
        so bad PC may managed to find C250i but not C3350i. In that case you will have dropped packets etc. in your ping.
        Did you restarted this PC just in case?
        Anyway, Good luck.
        • Flash
          • 378
          Re: Can't connect
          It's not likely causing your problem but if you have not upgraded the firmware to G00-45 it would be a good idea. Do not enable Bizhub Secure or V-care without upgrading.
            • 23006
            Re: Can't connect
            If you're waiting for the driver to discover every printer you'll be disappointed. Approximately 25% of all the driver installs I've done do not discover a static IP or hostname of the new printer. You have a couple choices. You can install the printer as local, then create a port with your static IP or hostname, or the driver will give you a place to manually select the IP address or hostname. Either way you end up with the same result. Maybe some of our members can explain why? =^..^=
