Ricoh Aficio MP C2500
  • qbert69
    • Mar 2013
    • 1152
    #16
    Re: Ricoh Aficio MP C2500
    The ONLY reason you're using TELNET in this instance is to Verify/Change SMB Information!!! If you are able to print to the MP C2500, don't monkey with any network settings in TELNET!!!
    Originally posted by Alexon
    Telnet
    ether:
    MAC-xxxxxxxxxxxxx
    static:
    inet 192.168.178.30 netmask 0.0.0.0 broadcast 0.0.0.0
    inet6 :: prefixlen 64
    current:
    inet xxx.xxx.xxx.xxx netmask 255.255.255.0 broadcast xxx.xxx.xxx.xxx
    hostname MPC2500
    Default gateway:xxx.xxx.xxx.xxx (192.168.178.254)
    It's mean that Ricoh have a Int. with static IP, should I delete or use this settings in my network?
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • Alexon
      • Jun 2020
      • 11
      #17
      After I put on the SMB v2, Ricoh allow to connect to the host PC.
      Tested out connectivity and I can browse folders in PC user from Ricoh screen.
      I also change port for 445 and CAL : 1
      Now, when I try scan to folder I have msg:
      But as I read before this Aficio MPC 2500 not support SMB v2 without firmware update. Link bellow:
      Effects of disabling SMBv1: Multifunction Printers and Laser Printers | Products & Services | Global | Ricoh
      Any fresh look advice?
      • qbert69
        • Mar 2013
        • 1152
        #18
        Turn On SMB V1 in System Program Features. [emoji41][emoji1303] If that option doesn't show period, there may be a setting in gpedit or registry that is disabling it from showing!!! Aside from that, I have no other advice for you other than what I have given in this thread!!! As it stands, the MFP is EOL & customer really needs to upgrade for security reasons!!!
        Sent from my SM-N950U1 using Tapatalk
        • tsbservice
          Field tech
          • 8020
          #19
          My advice is to contact this guy:
          https://www.copytechnet.com/forums/m...pier-tech.html
          For sure it will be wise to update machine FW and use SMBv2.
          • Polo-022
            • Sep 2007
            • 486
            #20
            Special Firmware : B2385605L_LRC00451.fwu in order to scan SMB
            from Windows 8 and afterwards.
            I have an MP C 2500 in my office for test purposes and it scans to folder
            for Windows 10 Home.
            I didn't test it with "Pro" version. But,
            lately i cannot set up Scan to Folder in Windows 10 Pro enviroment,
            for an MP3555, MP2014, MP C5000.
            All above suggested adjustments have been done.
            • Alexon
              • Jun 2020
              • 11
              #21
              Thank you all of you for help,
              I think the problem is that ISP blocked this ports on the modem/router level.
              Now I try to connect to FTP IIS server.
              FTP server work properly. I can connect from my other device,
              but I still don't find exact information (syntax) how fill out the Ricoh FTP authentication fields with Win ISS credentials.
              What I did:
              On the Ricoh screen choose FTP
              > Server Name: WORK-STATION
              > Path: \\FTP-Scans\ (this folder create on the C:, with necessary rights for the user bellow)
              > User name:
              > Password:
              Port No. 21
              Issue: Connection with PC has failed. Check the settings.
                • 37529
                #22
                What I did:
                > User name:
                > Password:
                Port No. 21
                The ISP (internet service provider) cannot block scan to folder.
                If you turn on SMBv1 service on the PC, the next Microsoft Security Update will turn it off.
                If you want to use FTP I would suggest FileZilla Server or a similar software. A lot more support available for setting it up.
                A work around is to scan to the MP C2500 internal Document Server. You can then use WIM to pull it to your computer.
                • qbert69
                  • Mar 2013
                  • 1152
                  #23
                  Not sure if you work on this Vintage of MP C2500 machine but I don't believe you can pull down documents to your PC that have been scanned into the document server...only see thumbnails & initiate printing a document from the PC that's already in the MFP document server. Heck, this machine doesn't even have a built-in USB port that you can scan to!!![emoji15] Another viable option would be Pull-Scan with Network TWAIN plug-in & host software!!!
                  • Alexon
                    • Jun 2020
                    • 11
                    #24
                    Thank you,
                    The ISP (internet service provider) cannot block scan to folder - yes, you are right, it's not.
                    The browsing of folder work, but transmission foult. In SMB mode.
                    Now I try to figure out with FTP.
                    • qbert69
                      • Mar 2013
                      • 1152
                      #25
                      Pull-Scan with Network TWAIN Plug-In in a host program would probably work too!!!
                      NAPS2 - Scan documents to PDF and more, as simply as possible
                      Windows 7 X64 TWAIN Driver (Might Work With 10!!!)
                      Thank you,
                        • 37529
                        #26
                        • Alexon
                          • Jun 2020
                          • 11
                          #27
                          Sirs,
                          thank you one more time to all of you.
                          The trick is that IIS FTP server assign index ( / ) page and what you need it is topologie how to fill out credentials and path in Ricoh WEB app or in the screen of Ricoh.
                          I attached pictures maybe it will be useful. I saw a lot of questions in web forums regard this issue.
                          0-02-0a-43a0b778b904a121d81ab4bfa8b6cf67f39636ef54bbba56347b10fc648adec8_27fa4c46.jpg
                          This what you will see after you connected:
                          0-02-0a-948e979096297d305d8f0d586e194f04320de8e2088d95ec255c346acf2c5352_2e279125.jpg
                          The scan works fine in both modes the pdf and the tif.
                          Thank you and FTP.
