Ricoh Aficio MP C2500
  • Alexon
    • Jun 2020
    • 11
    Dear Sirs,
    I try to setup Ricoh Aficio MP C2500 scan folder with Win10 64 pro.
    Cannot find the specified path... (when I try to scan the shared folder).
    SMD is active;
    firewall checked;
    ping did from the printer to host PC;
    DHCP assigns IP;
    network and sharing checked to allow ON;
    NetBIOS over Tcpip - Enabled;
    Protocol : SMB
    Path : \\WORK-STATION\Scans
    Please give your kind advice ?
    • 22801
    Re: Ricoh Aficio MP C2500
    Originally posted by Alexon
    Dear Sirs,
    SMD is active;
    firewall checked;
    DHCP assigns IP;
    Protocol : SMB
    which version of SMB are you trying to use?
    SMB1 doesn't work on a Win10 system..
    search the forums for SMB1 problems
    • qbert69
      • Mar 2013
      • 1152
      Dear Sirs,
      SMD is active;
      firewall checked;
      DHCP assigns IP;
      Protocol : SMB
      That machine is no longer supported for security & firmware updates...End of Life. Best you can do is go into system settings, programs & features and turn on SMB V1, as Windows 10 defaults to V2/V3 for security purposes. Good Luck![emoji41][emoji1303]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • qbert69
        • Mar 2013
        • 1152
        Gotta turn on SMB V1 under program features![emoji41][emoji1303]
        • Alexon
          • Jun 2020
          • 11
          Windows features on or off >>>
          Check SMB 1.0/CIFS Feli Sharing Support
          SMB direct too
            • 22801
            not a safe suggestion now that more n more malware is being written.
            • Alexon
              • Jun 2020
              • 11
              Yes, I dane with this, but still not work
              SMB direct too
              My option end after this and I decide to ask you guys.
              • Alexon
                • Jun 2020
                • 11
                Strange, but I don't have in my list of features (v2/v3).
                • qbert69
                  • Mar 2013
                  • 1152
                  See Picture. Are you running Windows 10 Professional or a Home Version???[emoji848]
                  • qbert69
                    • Mar 2013
                    • 1152
                    Also there is the matter of what port the MP C2500 is set to...is it port 139 or 445? If I remember correctly on this vintage of machine there is no way to set it through the machine web page...you have to do it through TELNET into the machine!!![emoji15] If I remember correctly, Windows 10 defaults to 445 for SMB V1.
                    • Alexon
                      • Jun 2020
                      • 11
                      This things done:
                      FeatureName : SMB1Protocol
                      DisplayName : SMB 1.0/CIFS File Sharing Support
                      Description : Support for the SMB 1.0/CIFS file sharing protocol and the Computer Browser protocol.
                      RestartRequired : Possible
                      State : Enabled
                      CustomProperties :
                      ServerComponent\Description : Support for the SMB 1.0/CIFS file sharing protocol and the Computer Browser protocol.
                      ServerComponent\DisplayName : SMB 1.0/CIFS File Sharing Support
                      ServerComponent\Id : 487
                      ServerComponent\Type : Feature
                      ServerComponent\UniqueName : FS-SMB1
                      ServerComponent\Deploys\Update\Name : SMB1Protocol
                      I use the Win Pro
                      • qbert69
                        • Mar 2013
                        • 1152
                        This things done:
                        State : Enabled
                        CustomProperties :
                        I use the Win Pro
                        • qbert69
                          • Mar 2013
                          • 1152
                          Good Info....
                          https://www.corsolutions.co.uk/blog/ricoh-copier-scan-to-folder-smb-issue
                          • qbert69
                            • Mar 2013
                            • 1152
                            Also make sure your "Network Location" Is set to Private/Work and NOT Public!!! Make sure Windows 10 has all updates applied, especially security updates, as I've noticed Microsoft will shutdown certain functionalities until updates are applied and sometimes the PC needs to be restarted during/after updates. Additionally, if you run 3rd. Party security software such as AVG, Kaspersky, etc., make sure you have made a security exception for that specific folder you are scanning to!!!
                            • Alexon
                              • Jun 2020
                              • 11
                              Telnet
                              ether:
                              MAC-xxxxxxxxxxxxx
                              static:
                              inet 192.168.178.30 netmask 0.0.0.0 broadcast 0.0.0.0
                              inet6 :: prefixlen 64
                              current:
                              inet xxx.xxx.xxx.xxx netmask 255.255.255.0 broadcast xxx.xxx.xxx.xxx
                              hostname MPC2500
                              Default gateway:xxx.xxx.xxx.xxx (192.168.178.254)
                              It's mean that Ricoh have a Int. with static IP, should I delete or use this settings in my network?
