Remote operation panel for Ricoh MP C3002 ?
  • whitecat
    • Nov 2012
    • 43
    Hello , is posible to use remote operation panel on this machine ( mpc3002)? if so , how to enable it ? Thank you.
  • ThePomqueteer
    • Sep 2016
    • 73
    Re: Remote operation panel for Ricoh MP C3002 ?
    Unfortunately I believe its only the Cxx04 series and up. Maybe the 03's since they had smart op panel capability but I've only seen it on Cxx04's and up
    • tjvincent
      • 280
      Yes, it's only on machines with a Smart Panel version 2 and newer.
      • whitecat
        • Nov 2012
        • 43
        Thank you , srry for comeing so late with a response. Problem is that we have to implement a solution , equitrack , and IT support sustains that EQuitrack can be installed only on machines with remote panel.
        If u know from what machines and up EQuitack was implemented i would apreciate. If im not wrong i c it on MP 4001 .
        What was the oldest machine u c EQuitrack implemented ?
        Thank you again
        • copier tech
          • 8285
          Thank you again
          Yes you can install Equitrack on the MP C3002.
            • 37711
            Sounds to me like either IT is too lazy to go to the machine location to preform the installation or they don't know how to use WIM.
