Smb scanning not worrking canon iradv c5255/c5051
  • niyaskarimba
    • Sep 2014
    • 110
    Dear All,
    SMB Scanning not working for few pcs (CANON IRADVC 5051/5250)form different customer locations tried the follow setting
    1.SMB1 is enabled(Programs & features)
    2.checked all the settings in network & sharing center(Password protected sharing is off)
    3.Checked & varrified inbound rules in the firewall setting
    4.Tried by turn off firewalls in the antivirus also
    5.Also enabled netbios over TCP IP
    6.Also updated the machine firmware to support SMB V2/SMB V3.
    Main problem is while trying by search host form the machine it is discoveing the pc name or IP adress but after touching its says "no response from the server"
    It all happends after thewindows updates.
    Kindly suggest any other solution please.
    Thanks in advance.
  • n25an
    • 1030
    Re: Smb scanning not worrking canon iradv c5255/c5051
    Originally posted by niyaskarimba
    Dear All,
    Thanks in advance.
    verify you can scan to your laptop from the copier...
    if thats good then
    on the destination computer for the scans on customers network
    turn on smb settings in additional features... all of the smb settings
    and make sure the network is private or home not public...
    verify that the account is admin
    reboot... and test scanning again...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • tsbservice
      Field tech
      • 8020
      Also make sure network discovery and file sharing are turned on in Windows settings.
        • 8167
        Dear All,
        Thanks in advance.
        This was a known issue, uninstall the latest Windows update that is causing the failed SMB scan.
        • n25an
          • 1030
          the update that broke smb on windows 10 is 1709... the link below detailed how it was handled
          • niyaskarimba
            • Sep 2014
            • 110
            Dear All,
            Thanks in advance.
            After Updating the latest windows update(20H2) it fixed our scanning issue.Thanks for all of your supports.
              • 16402
              I just read thru this thread and the links posted. After a little research, it seems that mostly what's being affected are the older machines that are still using SMB1. It appears that SMB2 & 3 aren't being affected. I haven't had any issues.
              See link below:
              Fix: Cannot Access Network Shares after Update 1709 - Appuals.com
