Prtanista /FM Audit
  • Max
    • Oct 2011
    • 552
    Prtanista /FM Audit
    HI. We use Printanista/ FM audit and waste tone alerts stop working on a random basis. Two weeks ago I re-did the alert definition and it hasn't worked. Emailed technical support and unfortunately still waiting. Would someone be able to take a screenshot of the waste alert configuration so I can compare it to ours, please? Or perhaps some instructions.
    Many thanks.
  • JLSam
    • Jun 2015
    • 605
    Wow, no response?
    We use Printanista, from countless installs, I can tell you that as of right now, there are no waste box alerts for printanista.
    What we do is set up a free google account for the machine, and set up e-mail alerts as well as having printanista installed.
    If you ever find out though, let us know. :\
    • Max
      • Oct 2011
      • 552
      I got to the bottom of it. There's a way. It's not something you could work out by yourself. Printanista support explained it eventually.
      • mojorolla
        The Wolf
        • 2583
        This has always been an issue with FMA; sometimes they work, sometimes they don't.
        I run a Service Alert report every morning to catch the service alerts that would normally occur if the software actually worked.
        REPORTS>DEVICE ALERT HISTORY>un-check Supplies and check Service, set # of days to look at, click Generate.
        • ThisPete
          Too old to care
          • Jun 2014
          • 166
          And the answer was?...
            • 37316
            Contact Printanista support.
            • ThisPete
              Too old to care
              • Jun 2014
              • 166
              Not the best of support services to have to deal with though..
              Nearly as bad as Asolvi...
