Scan to SMB
    • 16401
    Scan to SMB
    I ran into a strange occurrence the other day that I'm having a hard time wrapping my mind around. Perhaps some can shine some light on it.
    I have a client (car lot) that has about 15 PC that scan to folder. This is all wireless. I was called out because a handful of PC would no longer scan. After I updated the PC's, I ended up having to delete the shared folder and create new ones in order to get it to work.
    Here's the strange thing that happened. When I scanned to one of the PC's, the document appeared in the scan folder on the intended destination but also was in the scan folder on a totally different PC.
    Thoughts?
    • 16401
    Re: Scan to SMB
    By the way, I'm using hostname, not IP address.
      • 23009
      Re: Scan to SMB
      I know it shouldn't happen, but if you have several destination sub-folders of the same name within the shared folder (i.e.: "scans"), I've had the same document populate three or more sub-folders at the same time. The solution was simple: rename the sub-folder to a unique name, even if it's a single character different (i.e.: "scans1", "scans2", etc.).
      I know that you said that they were different PC's, but this is the closest that I could come up with. =^..^=
        • 16401
        Re: Scan to SMB
        Interesting but there's no sub-folders in my situation.
        Allow me to fill in some blanks that I failed to mention.
        I created a new user on each PC that I called "Kyocera" and I used the same password for each PC. I did this because the salesmen were always changing their password and scan was broken. Every shared folder on all the PC's is named 'Scan'.
        But it makes no sense to me that when I scan a document to one user's PC that it goes to 2 different PC's.
        Is it possible that an IP address could be resolved to 2 different hostnames? That's all I can come up with?
        PS - I didn't have a lot of time to work on it that particular day. I'm sure I'll have to go back at some point.
          • 16401
          Re: Scan to SMB
          Now that I think about it, could it be a duplicate IP address?
          • tsbservice
            Field tech
            • 8020
            Re: Scan to SMB
            I will start by rebooting PCs in question. As for wireless networking it always creates problems much better is hard wired, just saying
              • 16401
              Re: Scan to SMB
              Normally rebooting the copier will get scan to work again. But I also rebooted the PC's and router. No dice.
              I agree that wireless is more problematic but you know how customers are. They move into these old buildings with no ethernet jacks and go wireless because they don't want to spend the money on cat 5 drops. What can ya do?
                • 30271
                Re: Scan to SMB
                What device converts hostnames to ipaddress. Yep you have your answer.
                • copyrooks
                  • Oct 2013
                  • 210
                  Re: Scan to SMB
                  Do the folders happen to be a one drive folder that might be shared by all users? Had a similar problem with a Konica 227. I ended up creating non one drive folders to avoid that mess.
                  • Vincent128
                    • Sep 2015
                    • 349
                    Re: Scan to SMB
                    In small office situations when they have zero IT and little computer knowledge; I just scan to MFP and map the share as a local drive. Training them to move or copy out anything they want long term as I have the copier set to delete anything 90 days old.
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Re: Scan to SMB
                      It's more likely that it's user error in adding multiple destinations when scanning, or a stale DNS entry that's still resolving the IP to that of another machine. What's the MFP using for DNS? If there's any external DNS servers listed remove them and let the internal one forward as it needs.
                      A duplicate IP on the network would give you errors on one or more of the hosts, unless one was set to a static IP for an IP in the DHCP scope which would essentially blind it to any DHCP collisions.
                        • 16401
                        Re: Scan to SMB
                        The MFP is using the IP address of the router as the DNS. I can't swear to it, but I don't think there are any external DNS servers being used. I'll double check. I'll be going back to this account one day next week. This should be a good opportunity for me to learn as I've never encountered this particular problem.
                          • 30271
                          Re: Scan to SMB
                          Remember your training Luke?
                          what device and what layer of the OSI model controls the delivery.
                            • 16401
                            Re: Scan to SMB
                            That depends. In this setup, all they have is an ISP router and a bunch of PC's on a wireless network. So, according to my training, the hostname is resolved at the router and the PC keeps a DNS cache that it checks first.
                            BTW: I've never seen any of the Star War movies.
                            PS - Application Layer
                              • 30271
                              Re: Scan to SMB
                              What do think would happen if two of Pc's have the same hostnames. Yep seen it.
