Mac Printing
    • 37502
    #16
    Re: Mac Printing
    Originally posted by CoreyAbels
    I have not tried this yet, but there is a hypothetical problem with this solution, the customer is using PaperCut. This solution may get the job to print properly, but I then lose the ability to track jobs through PaperCut, correct?
    Yes sir, I have contacted the Kyo Help Desk and I was asked to switch the PDL from KPDL (default) to PCL and see if that changes the print job behavior (spoiler alert..it had ZERO effect) LOL
    I am also using the latest Mac Print Driver.
    Have you tried calling the PaperCut help desk? You do have the PaperCut software installed on the Mac?
    • rthonpm
      • Aug 2007
      • 2854
      #17
      Re: Mac Printing
      You should have mentioned PaperCut in your initial post. It could have cleaned up a lot of guesswork.
      Sent from my Pixel 6 Pro using Tapatalk
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        #18
        Re: Mac Printing
        PaperCut, Equtrac, Streamline, etc...all seem to not get mentioned when there is a print issue.
        It completely changes things.
        I would think LPRing directly would bypass it, but I can't be sure.
        • CoreyAbels
          • Dec 2014
          • 91
          #19
          Re: Mac Printing
          I have bypassed PaperCut during testing. All testing has been direct IP printing.
          Sent from my Pixel 7 using Tapatalk
          • CoreyAbels
            • Dec 2014
            • 91
            #20
            Re: Mac Printing
            It does change things, but for my testing purposes I have bypassed PaperCut to eliminate it as a potential problem. The issues described occur while direct IP printing, NO PaperCut.
            • PrintWhisperer
              • Feb 2018
              • 472
              #21
              Re: Mac Printing
              Here is a resource to learn about FTP on MAC. It shows a Finder method, a Terminal method, and some software which can ease the process (not required though)
              How to Use FTP on Mac: Step-by-Step Guide | Commander One
              FTP transfer is not 'Direct IP' printing, nor is it truly a print operation from the MAC's perspective. No spooler involvement. You do not open the file in any application nor have any print options to select. It is a straight up file transfer/file copy
              Be aware that the command PUT <filepath/filename> requires no destination folder, just the path/name of the file to be sent.
              "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
              • CoreyAbels
                • Dec 2014
                • 91
                #22
                Re: Mac Printing
                Yes sir, I have contacted the PaperCut support team, however one of my first steps was bypassing PaperCut entirely. The Macbooks are direct IP printing and using the PaperCut Client as the method of assigning prints to the proper account. Thus, the jobs are spooling on the Macbook and only touching the PaperCut server after the job is spooled to ask what account the job is assigned to. The problem seems to be a cut and dried Mac issue; and I have yet to find any type of configuration method that changes the print spool output to offload the print job AS it spools not AFTER it spools while still keeping the PaperCut server in the loop so that the user can track print output. The customer needs to bill clients accordingly and in a law office this is not optional LOL
                • CoreyAbels
                  • Dec 2014
                  • 91
                  #23
                  Re: Mac Printing
                  This is quite interesting. You can essentially transfer the file, via FTP, to the copier (HDD), bypassing the print driver/spooler altogether? You would then be beholden to however the copier is set to process print jobs (Color, Duplex, Etc)?
                    • 37502
                    #24
                    Re: Mac Printing
                    You never replied to my first question. The Apple Support Community is a group of Apple users. It is highly likely that at least one of them will be able to tell you how to set the spool to start printing immediately.
                    Have you tried posting a question to the Apple Support Community? Be sure to mention that you want it to start printing immediately. Official Apple Support Community
                    • CoreyAbels
                      • Dec 2014
                      • 91
                      #25
                      Re: Mac Printing
                      I did reply to your first question, I have posted to the Apple Support Community since then, and I have not received any replies or input yet. Thank you!
