scan to document server copier series
  • aviso66
    • Dec 2012
    • 202
    Recently i tested scan to document server using our ricoh mpc4503 and mp5000. surprisingly i am able to download those document from the webimage. because some older model like the mp3351, i tested it before when i scan to document server and access the document through the webimage, i am not able to retrieve the file or download it
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Re: scan to document server copier series
    You need the file format converter option in order to download the files from the document server.
    This is not an SD card, software, or firmware. It is a physical PCB that installs in the MFP.
      • 37529
      What are you logging into WIM as. I know on older models you had to log in as a user, not an administrator. Administrator(s) could only see thumbnails.
      • anothertech
        • 1771
        That's good to know. I've been looking for a way to do that.
        • aviso66
          • Dec 2012
          • 202
          ok, i didnt login i just go into wim and straight to document server.
          Do you mean i can login as using the username and password that i created from the address book?
            • 37529
            The man thing is that an admin cannot download from the Document Server. Just as an admin cannot use any of the Functions.
            I had a customer with a C2550 that used it all the time.
