Win 11 Print Driver icons taking up to 15 minute to appear.
    • 8333
    I have noticed lately on multiple computers in multiple locations when installing print drivers that the related icon to the print driver often does not appear in the control panel until maybe 10-15 minutes later.
    This can really lengthen the tine to complete an install especially with multiple computers.
    I have tried restarting the computer, restaring the print spooler and adding prints via printermanagement.msc .
    Any idea what is going on?
    • 16550
    Re: Win 11 Print Driver icons taking up to 15 minute to appear.
    Have you removed all of the old drivers?
      • 8333
      One Win 11 PC can print to multiple printer/ copiers.
      • rthonpm
        • Aug 2007
        • 2860
        Why even bother with Control Panel installs? It's all but deprecated and it's just as easy through Settings from the Start Menu.
        Outside of some initial BitLocker and power settings I don't even open Control Panel any longer.
        Sent from my Pixel 6 Pro using Tapatalk
        • Hansoon
          • Sep 2007
          • 3401
          Had exactly the effect SalesServiceGuy described by a recent install, and it drove me nuts in the beginning. I used as always the Settings from the Start Menu.......
          Hans
          • Saturn
            • Nov 2023
            • 173
            Open a command prompt and run the command: shell:::{26EE0668-A00A-44D7-9371-BEB064C98683}\0\::{2227A280-3AEA-1069-A2DE-08002B30309D} to get the Windows XP/7 Printer Dialogue. It will show all the installed printers.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
              • 8333
              Interesting. I never thought to right click Settings on the Windows Start icon. That gets me to Printers & Scanners a bit faster but the same much delayed appearance of the correct printer icons remain.
              • dalewb74
                • Feb 2018
                • 1167
                you are using the print driver installer from the manufacture, not using the windows printer install?
                • B0265
                  • Jan 2007
                  • 718
                  Try this, it has worked in W10:
                  Device setup in progress - Printix Administrator Manual - 1
                  • Duplicator
                    • May 2022
                    • 268
                    I believe this is related to a recent Windows patch. We have one computer that has the cumulative update from October 2023 and it doesn't have the issue. All the other machines are on the January 2024 patch and they have this problem.
                    Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
                    If I helped you out, please give me a thumbs up! It helps my reputation.
                      • 8333
                      Yes, I always use the OEM print driver.
                      • kleankopy
                        • Feb 2016
                        • 116
                        Seeing the same thing when doing thru control panel or start icon. Seems to be the latest windows 11 update. Seem to start in last 30 days.
                          • 8333
                          ... I would agree. The slow to populate printer icon update seems to be a recent Win 11 update issue.
                            • 37641
                            I have had a similar situation years ago at a school district. If someone scanned something to their assigned folder on the file server, it would take an extended length of time before they could see it in their folder but the IT could login as administrator and it was there. I found that if they either went up or down one folder level and then back it was there. They had just updated from Server 2012 R2 to Server 2016.
                            • rrrohan
                              • Sep 2011
                              • 1977
                              Its not only windows 11. I had this on a brand new windows 10 PC on Monday
