Scanning from Copystar CS-C4035E to Mac OSX Leopard
    • 23008
    \\diehardprops\desktop\scans
    (to identify path: open scans folder, Action, Get Info: \\Users\diehardprops\desktop)
    skip authentication: No
    username: username
    password: password
    6. Disable the Mac Firewall:
    Open System Preferences. With that window open, go up to the top menu and select View > Security. In the Security Dialogue box that pops up, go to Firewall and select "Allow All Access".
    Can anybody help me fix the path? Or whatever else is wrong?
    blackcat4866 =^..^=
  • tsbservice
    Field tech
    • 8019
    Check out this:
    http://www.copytechnet.com/forums/co...-scan-smb.html
    and this:
    That may help or not but is just what I found
    • konisolver
      System Engineer
      • Oct 2007
      • 137
      The easiest way to SMB on a MAC is to connect your windows laptop and confirm the host/file path/ user and logon. Then copy and paste this info to your unit.
        • 23008
        Thanks tbs. I've seen those documents.
        konisolver: How will it help to know the Windows path? It is "scans" and that was one of the first attempts that failed. =^..^=
        • konisolver
          System Engineer
          • Oct 2007
          • 137
          Ask the customer to see if they let you connect to their network to capture the path and confirm username / password.
          Click on start --> Run --> type \\host name of mac\shared name ( if SMB is enable on the MAC you will get a pull down of all shared folders. Select the shared folder then you will get prompted for user name / password.) Now drop a file and delete a file to see if you have R/W permission. If all works now simply enter the information on your unit.
            • 23008
            Click on start --> Run --> type \host name of macshared name ( if SMB is enable on the MAC you will get a pull down of all shared folders. Select the shared folder then you will get prompted for user name / password.) Now drop a file and delete a file to see if you have R/W permission. If all works now simply enter the information on your unit.
            I lost you for a second. What sort of Mac has start --> Run --> ...?
            But you're talking about my XP connected to their network! This makes perfect sense. I may not get to try this out right away, but thanks, and I'll give it a shot. =^..^=
            • n25an
              • Jul 2008
              • 1030
              scan to mac
              go to this link Comp25 Tech Service Blog - Setting up scanning for mac from the mac side and then how to use it on the copier side
              Sad To Say I Don't Have a Life
              I do this stuff on the weekends too
