Vista x64; Multiple Print/Copy Issus
  • unisys12
    • 489
    I installed a Savin MLP31dnL today (B/W 31ppm printer) on a Vista Home Premium x64 and quickly found that it would not print multiple prints of the same document. In other words, you go; File, Print, select 3 copies to be printed, and click OK. Problem is that it will only print 1 copy of the document. I first noticed this in a Print Shop program, so I opened Word and created a two page document and performed the same procedure. Yep! With the same result.
    The client finally noticed I was starting to sweat bullets in a air condition room and explained that he has the same issue an Oki, a Kodak and a Epson. He said it did not start until he bought this particular PC, which is loaded with the above mentioned OS.
    Has any one seen this issue before and if so were you able to resolve it. I have tried different drivers (RPCS {Ricoh driver}, PCL & PostScript), but no luck. I tried searching Google, but nothing seems to pop out of anything I have read so far and Vista's x64 Forum has one post concerning this issue, but it is yet unresolved. Any help or input would be great guys... thanks!
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Hi, Unisys,
    Methinks that the answer you're seeking is contained in the link: Cannot print multiple copies - Microsoft Windows Vista Community Forums - Vistaheads
    It describes not having the correct permissions set on the temp folder, and how to rectify the issue.
    I hope this works for you!
    • unisys12
      • 489
      Awesome find... I called myself searching that same forum. I guess I didn't well enough. Thanks for the link and info.
      sigpic
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        No problemo.
        • unisys12
          • 489
          Well, I finally got back in touch with the customer again and went out to try what was suggested in that thread above and... it didn't work. Although, when checking, the USER account did not have "Full Control" of the windows\temp folder, and I gave it the proper permissions and even rebooted, it didn't resolve the issue.
          I'm going to head back and do some more searching. There has to be more people out there with this same problem.
          - Found one more thing, while searching... Check to make sure that the WINPrint processor is selected. Properties, Advanced, Print processor and choose WINPrint.
          - I also saw another that suggested checking/choosing "Collate" and that fixed their problem, but that is already chosen. And yeah, I unchecked it and tried that too. Damn this is almost depressing!!
          sigpic
          • unisys12
            • 489
            Got two responses from Ricoh today... One from tech support and the other from our regional solutions rep. As a company, we don't support non-professional OS's. Since this the OS in question is Vista Home, do not support it. On the other hand, my regional solutions rep gave me a good idea. And that is to load the driver on another XP or non-x64 PC and share the printer. From there, add the shared printer to the x64 PC, that way the processing will be done through the other PC and not the x64 PC.
            So this tells me that the problem is isolated in the print processor. Which then leads me to the tip listed above about making sure that the WinPrint processor is selected. So... that is what I will do.
            sigpic
              • 23009
              I don't know if this is any help, but I'm really curious.
              If you "print to file" from your laptop, then send the resulting file.prn to printer from the vista 64, do you get the multiple pages, or just singles?
              My guess is that you will get multiples. Did you try setting it up as a local USB, then sharing it out?
              I'll be interested in the results.
              • unisys12
                • 489
                No, unfortunately I did not set it up as USB, so I get a big TROUTSLAP for that. But, I have talked with a few other folks about this issue and they agree that it's most likely a Print Processor issue.
                I have left a message with the client to call me back, so we can schedule a time for me to return. I just haven't heard from him yet. It's not a hugh issue to him, but something he has been dealing with since getting the x64 PC and something he would like to get to the bottom of. I'm just helping him out.
                sigpic
                • XeroxTechBrazil
                  • Aug 2008
                  • 199
                  Vista Piece of Shista
                  I also have a workstation running Vista x64, lots of problems, Home, Premium, Ultimate, makes no difference. Lots of problems.
                  It reminds me of the Millenium Edition that Microsoft unloaded on everyone because they didn't have Win2K ready.
                  OS wise, we're kind of like where we were with the US automakers in the 50's when they didn't have any competition.
                  If history is any iindicator, Windows 7 will be a great OS, like Win2K was (and XP finally became)
                  • sammyrose20
                    Well same here even I am suffering from all these issues in vista...I didn't find vista as compatible with printer as xp is...I am addicted to XP don't feel like using vista...bad OS
                    • Captain Scott
                      • Dec 2008
                      • 166
                      Are any of the trays paper type settings adjusted.
                      Just an idea!!If any of the trays have been adjusted say to letterhead or thick1....try changing back to plain and resend. A long shot but may be a paper type mismatch error. Another thing to try is to turn off Auto continue and see if the machine comes up with a message after you have sent the job.
                      • unisys12
                        • 489
                        Update...
                        Since I had not been able to get back in touch with the client, I let this issue go. But today I got a call from him and he said that he just loaded Win7 Home Ultimate and has the same problem with all three printers.
                        As a reminder, the three printers are a Epson, Kodak and a Savin MLP31dn.
                        I set up a appointment to meet with him on Monday morning. That way I can check the print processor, plus possible load the Win7 drivers for this model. If their available. I know they are for a lot of our models, just haven't check on this one. (yeah, I just checked and they are, but they are the same as the Vistax64 drivers, so... feel sure there's no fix there)
                        Wish me luck!!
                        sigpic
                        • Jules Winfield
                          • Jul 2009
                          • 821
                          Home Ultimate?
                          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                          • unisys12
                            • 489
                            Originally posted by Jules Winfield
                            Home Ultimate?
                            Yeah, ok... my bad! Home Premium...
                            Anyway, come to find out the upgrade to Win7 Home Pre, solved the problem after all. Well, for the most part. IE8, Safari and Adobe Reader now print multiple copies of a job. But MS Works and The Print Shop 23 (uses this to create a 35+ page catalog) will not... no matter what.
                            I told the client to get rid of Works and Print Shop 23 and get a full version of MS Office 7. Maybe even download OpenOffice, just to see if it would work properly as well, then use it.
                            sigpic
