I installed a Savin MLP31dnL today (B/W 31ppm printer) on a Vista Home Premium x64 and quickly found that it would not print multiple prints of the same document. In other words, you go; File, Print, select 3 copies to be printed, and click OK. Problem is that it will only print 1 copy of the document. I first noticed this in a Print Shop program, so I opened Word and created a two page document and performed the same procedure. Yep! With the same result.
The client finally noticed I was starting to sweat bullets in a air condition room and explained that he has the same issue an Oki, a Kodak and a Epson. He said it did not start until he bought this particular PC, which is loaded with the above mentioned OS.
Has any one seen this issue before and if so were you able to resolve it. I have tried different drivers (RPCS {Ricoh driver}, PCL & PostScript), but no luck. I tried searching Google, but nothing seems to pop out of anything I have read so far and Vista's x64 Forum has one post concerning this issue, but it is yet unresolved. Any help or input would be great guys... thanks!
