Shutting down FTP ports for KM5035 scanner nic
  • copyman20
    • 207
    one of our customers (A bank) did a security audit and found that ftp for the NS30 nic card (scanner nic) for the KM 5035 was open. it did not require a user name or a password to get in. I can shut down all the other protocals except FTP. called up tech support and they claim that there is nothing they can do about it.
    Has anyone seen this issue? I would even except a solution that will allow me to change the user name & password.
    • 23008
    There has always been a security hole in scan to FTP, that's why it's so easy to set up. The newest version of the ScanFile Utility is supposed to solve this problem. I wonder if it will be backwards compatible? Don't know... =^..^=
    • copyman20
      • 207
      this does not have anything to do with the scan to ftp. this is logging into the ftp on the NIC for the scanner.
