e studio smb function
  • digicor
    • 1156
    how do i set up smb function on the estudio 200,230,280 ect, im in the web brouser , i have it turned on but still no connectivity, im familiar with the ricoh, and it has a brouse the net work feature, the toshiba seems not , where is the brouse function or is it needed to be turned on in the dservice mode??
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Do you have the scan enabler? If not then you can not scan. You either need the print and the scan enabler or you need the combo enabler.
    then in the web browser you go into admin then network then file save option.
    • TheOwl
      • Nov 2008
      • 1732
      There is no browse feature in the Toshiba copiers. If you want to scan to a netowrk folder, then you need to know what the UNC path is. For Example:
      \\servername\sharedfolder
      You will also require credentials for the machine to use when scanning. This could be a clients logon or the best approach is to create a user for the copier to use. If the client is running a domain, then don't forget to put the domain name followed by a backslash in front of the username.
      domain\username
      • digicor
        • 1156
        thanks i got it, i need the //pcname/folder this is all it was, minolta,ricoh are similar but never the same protocall....cant we all just get along??LOL
        can i use more than two specified locations? how do toshiba account for more thn 2 folder paths?
        • TheOwl
          • Nov 2008
          • 1732
          You can use the templates if you want to scan to more than two folder locations. You will how ever need to set either remote 1 or remote 2 to 'Allow user to select network folder to be used as destination'.
          From there, use the following to set a template for scanning:
          1. Registration
          2. Create a Template Folder as such (group for scanning templates)
          3. Click on an empty template
          4. Select scan (and the default should be scan to file)
          5. Click 'Select Agent'
          6. Enter in all of your desired settings. Just remember to untick 'Use local folder' so that scans aren't also sent to the HDD of the copier.
