Sharp MX3501N
The last screenshot you sent out is of the DNS server address. You can try putting in a public DNS to see if that will allow you to connect to the internet from the machine. Try these two numbers:
Primary: 208.67.222.222
Secondary: 208.67.220.220
From past experience you may also want to put in your ISP's DNS info or your Router's gateway address in one of those two fields.
Hope that helps.Comment
If it is an intermittent problem it may have something to do with authentication as well. Is the error code always the same. I believe CE-03 is the error code for Authentication failure. I recently had a customer with an ARM257 that would scan a couple times then not work for a few hours, then it would start again. I ended up diagnosing the problem by switching the mail server from theirs to mine (because I knew what the settings were supposed to be) and it worked every time. I have since notified their IT staff and told them it is something on their end.Comment
