A simple task turned into a very frustrated one. I was able to get one of these Sharps free of charge for my home office in which I need a good quality scanner. I wanted to setup the email option on the copier so that I could scan and send the scan to my email. I was able to connect everything and I can easily use the web interface using the IP settings of 192.168.0.17. I am using my simple GMAIL account for email and did my research on the settings and am using the following settings. At first, it worked usually. Then more and more, I kept on getting the error of CE-00, server not found. It is very inconsistent.
Lately, I cannot get it to work at all. My concern is that it worked initially with these settings, and therefore, the problem is hardware related, not software. Any thoughts or insight would be appreciated.
I have also tried to use the included software, Sharpdesk. It sees the scanner, but when I go to acquire images, it says that it cannot connect to the scanner. Makes no sense to me. Either of them will be sufficient for my needs, but one has to work and neither is right now.
Thank you
Thank you
