Sharp MX3501N
  • tomsocal2000
    • Aug 2010
    • 10
    Sharp MX3501N
    A simple task turned into a very frustrated one. I was able to get one of these Sharps free of charge for my home office in which I need a good quality scanner. I wanted to setup the email option on the copier so that I could scan and send the scan to my email. I was able to connect everything and I can easily use the web interface using the IP settings of 192.168.0.17. I am using my simple GMAIL account for email and did my research on the settings and am using the following settings. At first, it worked usually. Then more and more, I kept on getting the error of CE-00, server not found. It is very inconsistent.
    Lately, I cannot get it to work at all. My concern is that it worked initially with these settings, and therefore, the problem is hardware related, not software. Any thoughts or insight would be appreciated.
    I have also tried to use the included software, Sharpdesk. It sees the scanner, but when I go to acquire images, it says that it cannot connect to the scanner. Makes no sense to me. Either of them will be sufficient for my needs, but one has to work and neither is right now.
    Thank you
  • Dustin(WOP)
    • 223
    try these settings....worth a shot....these are the setting I use when dealing with a gmail client.
    DNS Settings
    Primary Server: 74.125.95.109
    Secondary Server: 74.125.95.17
    Domain Name: gmail.com
    SMTP Settings
    Primary Server: smtp.gmail.com
    Secondary Server: 74.125.95.109
    Reply email needs to be a valid email address such as your own
    put a tick next to smtp authentication
    put your email and your email accounts password in the feilds provided
    This is how I set up gmail account for driect scan to email. I will also include a detailed step by step instuctions on how to install sharpdesk and the scanning software.
    Installation Instructions For Sharpdesk(scanning)
    1) Screen should automatically pop up
    2) make sure english(united states) is selected
    3) click ok
    4) click next
    5) click next
    6) click yes
    7) enter username "your name" and leave company name blank
    8) enter serial #-found in manuals
    9) click next
    10) click next
    11) make sure typical is selected
    12) click next
    13) click next
    14) make sure accessories is highlighted
    15) click next
    16) WAIT.... (note: the install will hang at 92%, the computer did NOT freeze)
    17) select yes, restart now
    18) finish
    19) wait untill computer restarts
    20) search setup wizard will start
    21) click next
    22) select scanner from left side and click add
    23) click next
    24) enter name of persons computer you are sitting at
    25) click next
    26) click all 4 profiles on left side and click add
    27) click next
    28) click save
    29) click next
    30) click finish
    31) click next 6 times
    32) click cancel
    33) click ok
    34) click next
    35) click index now
    HOPE THIS HELPS!!!!!!!!!!!
    • tomsocal2000
      • Aug 2010
      • 10
      ON the email settings, I tried the settings and received a a SMTP authentication not supported error. So, it did not work. Any more ideas? Thank you
      • OMD-227
        Firstly, well done on getting a free color copier! Are you on any sort of service contract? I hope so, 'cos its going to hurt come service time! Those machines need alot of consumables/parts.
        In relation to your scanning problems, Gmail requires SSL Encryption for SMTP and POP3 .
        Under the SMTP settings, there may be a tick box marked SSL, tick this.
        Set the port number to 465 or 587.
        If there is no such option, update the machine to the latest firmware. Alot of scan issues were sorted out with newer firmware.
        Other than that, wait for Tmaged to come online. He's the connectivity God around these parts. I'm not really IT based, primarily service tech. I've got IT specialists I can pass these jobs over if needed to.
        Or, use the USB memory scan function if you need to use this machine now. Connect a USB thumb drive to the rear USB port, select Image Send, change mode to USB memory scan. It will scan as a JPG or PDF onto your thumb drive.
        • tomsocal2000
          • Aug 2010
          • 10
          It gets even better. I cannot find where an update of firmware is an option. I have looked and looked and then did a scan for all of the manuals for "firmware" with no results.
          • tmaged
            Owner/Service Manager
            • 1887
            The advice given here all looks good to me. SMTP server should be smtp.gmail.com like Dustin said. Then follow Wazza's instructions & change the port to 465 and use an SSL connection. Just remember, the connection test means it found the mail server, not that it authenticated. In my experience, unsupported means secure vs. nonsecure.
            You won't be able to update the firmware without having the firmware & maintenance codes.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
            • OMD-227
              Thanks Tony... I knew I was close.
              Tomsocal....Print out the system settings page, and let us know what the firmware versions say. As you are not a tech, you will be unable to update the firmware, but I can advise if the version on the machine should be updated.
              • tomsocal2000
                • Aug 2010
                • 10
                Ok, here is the system settings. I appreciate any help you can give.
                • OMD-227
                  You are running firmware from September 2006. Its very old. There have been alot of system changes in all the newer versions. It definitely should be updated. There are pages of information of the changes done.
                  • tomsocal2000
                    • Aug 2010
                    • 10
                    Yes, that does not surprise me. This copier was owned by a home builder that went bust in 2007 or so. One of the many. Thanks again.
                    • tomsocal2000
                      • Aug 2010
                      • 10
                      I believe that I am down to network settings now with my problem. I thought I have followed the gmail setup instrucitons that you have provided, but the current message has to do with the POP connection. Attached is the setup screens. Does anyone see anything wrong with this. And thank you for everyone who has helped me through this process.
                      • tmaged
                        • 1887
                        I don't think it needs to POP before SMTP, so you shouldn't need the POP setttings. POP is only for receiving. Make sure you do have ut set up in Gmail though.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • tomsocal2000
                          • Aug 2010
                          • 10
                          Here is my gmail settings and I think this is set right. It still says connecition failed
                          • tmaged
                            • 1887
                            Tom, the only things I can think of, are increasing the timeout to 60 seconds & making sure the reply email is a valid Gmail account. It shows ME @ gmail.com. Most servers will require this to be a valid account on the mail server to be able to send.
                            Beyond that, I'd try using wireshark to do packet captures. This should tell you exactly what's going on.
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            • AvisAustin
                              Direct Loan Servicing
                              Direct Loan Source
