Sharp MX3501N
  • tomsocal2000
    • Aug 2010
    • 10
    Originally posted by AvisAustin
    It definitely should be updated. There are pages of information of the changes done.
    Direct Loan Servicing
    Direct Loan Source
    I have updated the Firmware to the most current version. But I am still having the same email problems saying that it cannot connect to servers. I just have been too busy to work on the problem since I can scan to a memory stick as a fall back solution.
    Thank you.
    • bdcrandall13
      • Sep 2010
      • 236
      The last screenshot you sent out is of the DNS server address. You can try putting in a public DNS to see if that will allow you to connect to the internet from the machine. Try these two numbers:
      Primary: 208.67.222.222
      Secondary: 208.67.220.220
      From past experience you may also want to put in your ISP's DNS info or your Router's gateway address in one of those two fields.
      Hope that helps.
      • tomsocal2000
        • Aug 2010
        • 10
        Hope that helps.
        Thank you for this. I will take all the help I can get. What gets me is how inconsistent this problem is for me. It has worked the last 3 times I have used it, but then the next time, it won't.
        • bdcrandall13
          • Sep 2010
          • 236
          #19
          If it is an intermittent problem it may have something to do with authentication as well. Is the error code always the same. I believe CE-03 is the error code for Authentication failure. I recently had a customer with an ARM257 that would scan a couple times then not work for a few hours, then it would start again. I ended up diagnosing the problem by switching the mail server from theirs to mine (because I knew what the settings were supposed to be) and it worked every time. I have since notified their IT staff and told them it is something on their end.
