Smb authentication testing
  • n25an
    • Jul 2008
    • 1030
    SMB AUTHENTICATION TESTING...
    You guys know that sometimes when you setup scanning to smb on the domain there can be four or five ways to configure the settings...
    My question is this...
    Are there any command line tools that will give you a hint to which one will work...
    linux or windows tools are appreciated...
    or even smb clients that I can use...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1887
    It wont show you what will work for authentication, but you can test it by running it through run. It'll bring up the authentication box, if any is required. Ususally the domain name needs to be capitalized.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23008
      Thanks Tony.
      ...another tool in my IT toolbox. =^..^=
      • tmaged
        • Oct 2008
        • 1887
        Always happy to help. I had an instance where the folder name & share name were different. This is the quickest & easiest way to make sure you can get to what you're looking for. Then you KNOW it's an authentication problem & not a path issue.
        Hope that helps !
        -Tony
        www.dtios.com
