CANON IR3300
  • ARUN MISHRA
    • 80
    CANON IR3300
    Not printing //// LAN CARD CHECKS,,its ok //lan cabal is okkk////driver properly install////i ask more abut the ping
    sigpicARUN KUMAR MISHRA
  • Brian.Owens
    Canon print issue
    Can we get more info? Is the copier ps enabled? Which driver are you using ps or ufrII? Have you deleted the printer and reinstalled, or rebooted Pc? What happens when you print, does it fail or does the copier say error? Is the port an ip port? If not try adding an ip port. Sometimes if it is installed by the disk the the port has issues with the Pc.
    Also, is there virus protectionon the Pc? What have you tried printing? A test page, word doc, etc
    • ARUN MISHRA
      • 80
      usening pcl printer driver //copier pcl enabled // tctip enabled///try printing test page //i dont know more abut ping commend ///printer attach a lan switch ///and use local network //
      • Brian.Owens
        Does the print job fail at the Pc? What os is the driver
        Loaded on? What is the port? Start/printer/rt click printer/properties/ports if it isn't ip_192.168.... for example try it as an ip port. Have you tried more than one Pc?
        • ARUN MISHRA
          • 80
          yas pc say print job fail ////pc os windows xp and iuse pcl5e for xp os////the port is 192.168.1.8///printer ip is 192.168.1.8///yes try the next pc of this network..///
            • 22999
            To ping your printer go to the Start menu, then
            Run.
            On the line type: cmd
            then Enter.
            When the command line window comes up type in: ping 192.168.1.8
            then Enter.
            A successful ping will return in just a few milliseconds.
            Another simple test is to open your browser, then type on the address line: 192.168.1.8
            then Enter.You should then see the webpage for the desired printer.
            If either of these tests fails you must then discover why the printer is not connecting to the network. =^..^=
            • ARUN MISHRA
              • 80
              lan switch change and the copier is pinging ... thanks you.,, your feedback and guideline..
