Using the fax option on a konica minolta C353 with IP Phone Systems including IP Fax
  • SoCal Office Systems
    • Apr 2011
    • 17
    My customer brought this too me today and I was very stumped. They basically got a new phone IP Phone System, with no more normal phone line jacks. So they want to use their fax feature of their copier but I am unsure how this can even work now. Is there a way to set this up or are they SOL.
  • copytechman
    • Nov 2008
    • 926
    Re: Using the fax option on a konica minolta C353 with IP Phone Systems including IP
    Um, Yeah, no... Unless you setup an ATA for an analog line.. Even then it's dicey @ best.. Best bet is a plain old fashioned analog tel line for the fax.....
    Regards!
    A.
      • Apr 2011
      • 17
      I Just read that the C353 does internet faxing, with no phone lines.
      • MFPTech
        • 486
        I have a customer that uses FoIP but they have a modem where they connect the fax line from the copier and the network cable from the Network.
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1858
          Both the sending & receiving machines have to be ifax capable for it to work. The only way to get it to work somewhat reliably is slow modem speed, turn of error correction & bump the scan resolution down. That way you're sending as little info and as slow as possible.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
