Smtp Domain Name
  • redserv
    • May 2010
    • 307
    Smtp Domain Name
    hello guys, i have a quick question, some of my clients request scan to email with SHARP MFPs, howeveri will like to know if its possible for me to use the Domain Name under the SMTP settings, rather than the mail server IP address.i just use the IP address of the mail server, but always wanted to find out if a Domain Name will work, my second question is are there any tools available to get a customers email server ip address?thanks in advance.
  • Mooseface2r
    • Jan 2011
    • 114
    Re: Smtp Domain Name
    Yes you can use the host name of the SMTP server, make sure you include the DNS settings.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1887
      Most of the time if you ping the hostname of the mail server, it will reply with the IP address.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        It's normally preferred to use the host name of the mail server rather than the IP address.
        Although it's unlikely that the IP address would change, but I have had that happen already, as the mailserver was on DHCP.
        If you're "locked in" with a static IP, your scan-to-mail will fail should that happen.
        It's also possible that a host name could be pointing to a bank of several servers, where the IP address would be pointing at only one specifically.
        All of this becomes even more magnified if the customer is using a third party email provider, where the IP addresses are more likely to change, and seldom, if ever, with any notice.
          • 23008
          I have a customer that has a couple different SMTP IPs. It resolves to three distinct address, for sure, maybe more. The explanation that I got was that it was a rollover of some sort. When one address reached capacity, the next one resolved, etc.
          If someone has a better explanation I'd like to hear it. In any case, yes they use a hostname, and DNS is important.
          And yes you'll see the IP if you ping the hostname, but you won't necessarily get a response to the ping. Some SMTP servers do not respond to ping. =^..^=
          • Raymondd
            • Jan 2008
            • 108
            X10000
            • redserv
              • May 2010
              • 307
              thank you very much guys really appreciate the help, you learn everyday
              • morpk
                • Oct 2010
                • 97
                to be sure i would normally check the setting under the users outlook to see if they are using and ISP mail or an internal server then just to check what IP it is using open cmd type: nslookup the type the name it will resolve the IP and if you do this for the ISP mail server it will tell you what IP's it using e.g mail.bigpond.com will ussually reolve 2 or IP addresses. you can also telnet to the server to make sure it's talking correctly
                BEST practise use the hostname.
