emailing reports from command center
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    I have a TA 5500i machine I have been trying to monitor for certain jams we've had issues with over the last few weeks. This machine has scan to email set up on it so I know the SMTP settings are correct. I got to put my email address in for Email Recipient #1 to just have the machine email me any jams or service codes it has, but I am getting an 0x8009 error when I tell it to test send. I can't find this error anywhere so any help in what area I should be looking at would be appreciated.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
  • Mooseface2r
    • Jan 2011
    • 114
    Re: emailing reports from command center
    Im not sure about the code but...You say the machine is setup to scan to email, is it able to send externally. Sometimes the you can only email in the current domain if you haven't got the correct authentication details.
      • 23009
      You'll have better luck sending the reports to the copier administrator's email address, then have all emails from the MFP forwarded wherever you want by rule.
      Most of the places I have set up scan to email do not allow email destinations outside the domain. =^..^=
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        Sounds like a good work around. This is just a machine I want to monitor and this seems to be the easiest way without me going out everyday or calling the person who is there who isn't always around the machine to get accurate times or if jams happened. Thanx for the tips.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          was just googling for this error and it lead to this thread.
          another solutio , check for valid sender address.
          ISP: shaw telecom canada
          Idling colour developers are not healthy developers.
