SMB scan set up for KonicaMinolta Bizhub 223
  • Nelo
    • Aug 2025
    Tried setting up smb scaning on bizhub 223 and when retrieving networked pc's the machine displays error "failed to retrieve". This is the secound time for me to setup smb scaning witch my first setup was ok. The office network is Domain controled. Does smb work on domain network.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: SMB scan set up for KonicaMinolta Bizhub 223
    Whenever there is a connection error, try imputing the IP address instead of hostname. If the scan goes through, you need to enter the DNS information into the copier, even then sometimes it only likes IP
    The domain can be a pain in the ass. I have seen impenetrable domains, but I am not an IT professional.
    You can try to enter the domain name under the Network tab of the web interface, or try domain/username in the SMB page.
    • Nelo
      Thanks, will try it out.
      • TheOwl
        • Nov 2008
        • 1732
        You will need to make sure that:
        1. The domain DNS is entered in correctly
        2. The NTLM version is set to V2 or V1/V2
        You need the dmain DNS to tell the machine on which domain the username and password exists and you need NTML V2 to talk with Active Directory correctly when attempting to authenticate the scan.
          • 23009
          Excuse me Owl. Can you break out these statements in a little more detail for us less educated?
          I have pretty good success with Scan to SMB, but I consider most of it good fortune rather than skill. =^..^=
          • Nelo
            Will try that and come back with the results.
            • TheOwl
              • Nov 2008
              • 1732
              Here it is again with me putting a little more thought into it... lol
              Konica Minolta don't accept your typical Domainname\Username or username@domainname when authenticating. They rely on the DNS Domain name within the network settings so that they can add the domain name to the username. With out the DNS domain name set in to the network settings, the machine won't know the source in which the username and password have to be authicated with.
              As for the NTLM version, Active Directory (which is used when creating a domain) requires the use of NTML version 2. Out of the factory, Konica Minoltas are set to NTLM version 1 which stops the device from authenticating with Active Directory properly. The is a setting that will allow the machine to authenticate with both versions which is v1/v2 and can be set by:
              1. Administrator Settings
              2. Network Settings
              3. SMB Settings
              4. Client Settings
              5. NTLM
              • JR2ALTA
                • Feb 2010
                • 2033
                This is gold. Thanks.
                • Hansoon
                  • Sep 2007
                  • 3389
                  This is gold.
                  Its gold with diamonds all over it. Thanks indeed.
                  Hans
                  • TheOwl
                    • Nov 2008
                    • 1732
                    You should all thank the Blackcat too because I wouldn't have gone much further without being asked... lol
                      • 23009
                      I knew my ignorance must serve some purpose in the grand scheme of things ...
                      • Nelo
                        Thanks every one for your assistance, my castomer has firewalled smb setup on thier network, IT guy disabled and we were able to get it done. Thanks again.
                          • 23009
                          I've also had certain anti-virus programs block SMB scanning or printing. In this situation I'll temporarily turn off the anti-virus to prove that SMB is possible. I'm some sort of exception is required in the anti-virus, but that's up to the customer to figure out. =^..^=
                          • Techace
                            • 35
                            thanks and thanks alot
                            • morpk
                              • Oct 2010
                              • 97
                              it's also worth mentioning you need to have the correct share/ security settings around the scan folder i have had a few instances where i would get "Server Connection issues" because the security settings were tightened although my username and password, DNS and NTLM versions were correct
