Printing issue
  • Peter Sim
    • Sep 2008
    • 445
    Printing issue
    Hi all, please help.
    I have printing issue from my customer.
    They are air freinght company,print from their own software call LX1 to canon ir2870 show "PCL UFR ll version error".
    But for other branches, they can print from canon ir 3035.
    What are the posibility causes of this problem?For print base of ir2870 and ir3035 are the same?
    Thank you in advance.
  • TheOwl
    • Nov 2008
    • 1732
    Re: Printing issue
    If you have access to the other sites, then I would look at the following:
    1. Exactly how they are printing to the other machines (driver, direct PCL code)
    2. See what version drivers (if any) are being used at the other sites.
    3. If the software sends PCL directly to the machines, then see if an emulation type is being used.
    • Peter Sim
      • Sep 2008
      • 445
      Re: Printing issue
      We can't access to the other site( we are in diffrent states),is the IT guy inform us that they can print thru ir3035 from their software.
      • TheOwl
        • Nov 2008
        • 1732
        Re: Printing issue
        Are they printing directly to the printer or using a print driver?
        • Peter Sim
          • Sep 2008
          • 445
          Re: Printing issue
          Thank you for your reply.Is using print driver.We have fews unit ir2870 on the plant ,and they use certain software to print thru our machine ,only this software giving error to print out.
          We have no authority to check thru the driver from the server,we only inform by their IT guy,saying that the copier cannot be used.I need info and try to persuade the IT guy to try it again.
          • morpk
            • Oct 2010
            • 97
            Re: Printing issue
            This LX1 program is it UNIX based if so try using a generic driver or set up the driver as a ir 3035 just to see if that helps, also sound like the IT guys is being a bit hard to work with
            good luck to you.
              • 23009
              Re: Printing issue
              If you can get a data capture we could tell something from that. A data capture from the problem machine and a data capture from a working one. If the IT guy can get a print-to-file of the exact same document from both drivers, the code can be compared. I think you'll find a difference, like PCL5e versus PCL6.
              To confirm that it's not machine related, send the print-to-file from the working machine to the non-working machine. =^..^=
              • Peter Sim
                • Sep 2008
                • 445
                Re: Printing issue
                good luck to you.
                Thank you for your information ,i think the IT guy install the wrong driver(window base) if it LX1 is UNIX base.
                • Peter Sim
                  • Sep 2008
                  • 445
                  Re: Printing issue
                  Ya,think you for your suggestion
