Re: Anyone care to try to explain this IP conundrum?
Surprisingly I've done most of these things:
True.
I don't really know who's handing out addresses. The wireless PC's and router do have addresses in the same range: 10.0.0.xxx
My laptop does connect wirelessly in the 10.0.0.xxx range, but via one of the four RJ45 ports on the back of the router I get 169.254.188.xxx (APIPA, correct? Meaning no real IP is handed out.) If both the MFP and the laptop are plugged into the router they can communicate on 10.0.0.xxx or 169.254.188.xxx or crossways. I know it's illogical, but there it is. The router will hand out 169.254.188.xxx addresses, but if i set static 10.0.0.xxx addresses they work too if both devices are wired.
Which device? Don't know.
DHCP traffic cross both devices? I don't think I understand the question.
IP/Subnet/Gateway? All the wireless devices and the previous printer were at 10.0.0.xxx/255.255.255.0/10.0.0.1
A total of 8 devices were picked up by NetScan. Four were wireless PCs and laptops including my own. The other four? Who knows? One may be the router. One might be the DSL modem.
This portion of my network site survey was blank, but I have some confidence that this part is correct.
I've seen this before on a very confusing setup a few years ago. There was an Airport (Mac Wireless?), a wireless router, and a seperate wired network. Their IT was coaching me over the phone. I honestly have no idea what I was doing, just punching keys as prompted. There were three seperate IP ranges for sure. What a mess. Some of the wireless clients could see the printer. Some of the wired clients could see the printer. Ugggh.
I suspect this isn't going to be an option. There are 8 wireless networks in a relatively small building, and I imagine there was some coordination so as not to tread on each others toes.
Ok. Silly test:
1. 10.0.0.xxx/255.255.255.0/10.0.0.1, DNS1 and DNS2: 216.xxx.xxx.xxx, IPV6 (it was only 6 or 8 numeric digits, I don't know the format), DHCP: 10.0.0.1
2. No real wired network, just ports on the back of the wireless router.
3. DHCP pulls 169.254.188.xxx/255.255.0.0/169.254.188.xxx (IP same as Gateway), No DNS, No WINS, No DHCP, No IPv6, No domain, not much of anything.
Into the modem? There were three ports. One connecting the modem to the router. When I tried to use either of the other two I got nothing. No attempt to connect, no change. I did not try connecting to the one remaining port because I would have downed their network.
There were a total of 5 ports on the wireless router, the first connecting the modem. All pulled 169.254.188.xxx addresses as above. Does that clarify anything? By the way, thanks for sticking with me. I'm faily accurate with my observations, for what that's worth. =^..^=
True.
Ok. Silly test:
