Network switch dead after connecting printer
  • mascan42
    • Oct 2008
    • 484
    I have a customer whose network switch died (no lights except power). When he replaced it, the new one died as well. When he got a third one, he plugged the cables in one at a time, and when he plugged in the network printer, that one died as well. The switch remained dead even after unplugging the printer, and his newest one works fine since he didn't plug the printer into it. I can't think what could be causing this . . . could the NIC card be sending some sort of feedback that's killing the switch?
  • Shadow
    PHD in Sh!t Disturbing
    • Sep 2011
    • 455
    Re: Network switch dead after connecting printer
    does the client have the printer network cable plugged in to a surge protector between the switch and the machine?
    I have seen surge protectors cause this very same issue when they go bad, especially the cheap ones.
    $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
    • Bantams
      • Jun 2012
      • 603
      Would be unusual for the printer to be the cause I would check the Network cable to the printer first maybe its broken and shorting out.
      • TheOwl
        • Nov 2008
        • 1732
        What happens if you move the machine to another data outlet and plug the copier into the network from there?
        I have never heard of a NIC as such blowing up a switch, but I have heard of PoE injectors going bad and pushing voltage down the wrong line, I have seen shorts in the cabling with power, hell, I have even seen dead switches from mice piss, but never a NIC on its own killing an entire switch.
        Is the switch of a quality brand or is it cheap and nasty?
        • ddude
          General Troublemaker
          • 473
          Also consider trying a different printer cable (KISS).....
          2000 mockingbirds = 2 kilomockingbirds
            • 23009
            So what happens when you connect via crossover to your laptop? Like ddude, the crushed cable makes the most sense. =^..^=
