Is there a definitive test ...
    • 23009
    ... to determine if the proper port is unblocked/open? Whether its port 21 for FTP, 139 or 445 for SMB, 25 or 587 for email, 9100 for printing, I can never be sure, just cause the function isn't working. Maybe a command prompt? An external utility? Or just admin rights to the main server? =^..^=
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Is there a definitive test ...
    telnet ip_address port_number
    that should give you a clue.
      • 23009
      So for example:
      C:\Documents and Settings\user>telnet 192.168.0.100:139
      or something like that? And what sort of response would I expect?
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Ask and ye shall receive.
        It's a free utility from Micro$oft.
        Actually, I just used it again today.
        Just run "portqueryui.exe". Nothing to install!
        • sdrawkcab
          Confused & Bewildered
          • Jun 2009
          • 317
          You might find this useful
          TCPView
          TCPView
          Some days, it's just not worth chewing through the restraints
            • 23009
            Thank you sir. I'll try it out tomorrow (time allowing).
            You're a gentleman and a scholar. Thanks Ken. =^..^=
            • Hansoon
              • Sep 2007
              • 3386
              NetworkScan does this if properly configured:
              SoftPerfect Network Scanner: fast and free network scanner
              Go to Options>Program Options>Additional>Check for open TCP ports
              Hans
                • 23009
                Marvelous! Three possible outcomes: LISTENING, FILTERED, or LISTENING or FILTERED. I'm not sure whats being specified in the third case, but when I tested our SMTP, SMB, and FTP, I got the expected results.
                Hans
                Maybe I missed a step, but it only seems to check port 80. I experiment a little more to see if I can get more useful results.
                Thanks All. This will help a lot. =^..^=
                  • 23009
                  Hans
                  I found it. Nice! I can list all the usual ports to check on the "Additional" page. It pings each IP and checks each port listed. Someday I should learn how to use all these great tools I have. Thanks Hans. =^..^=
                  • Hansoon
                    • Sep 2007
                    • 3386
                    Glad if I could help Cat.
                    Hans
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Glad to help.
                      I've used quite a few other tools, but I like the fact that it doesn't need to be installed. Quite handy if you need to run it on a customer's PC.
                        • 23009
                        Like LPR Jar, it looks like it would run from the USB stick. =^..^=
                        • leo34staffs
                          copierman
                          • Aug 2007
                          • 503
                          On the pc you want to check (providing your on it) you can use: cmd, netsh firewall show state or netsh firewall show config (This works on XP)
                          This will will provide some useful info on what the firewall is blocking, although it may be different for win 7
                          Networking skills are advantageous but use of a 3m vacuum cleaner is essential
                          • ruben
                            The New Guy
                            • Oct 2012
                            • 1203
                            On Windows 7 you can use "netsh advfirewall firewall show rule name=all > C:\firewall.log"
                            The filename and drive location you can change yourself.
                            • DAG COPIERS & COMPUTERS
                              • Oct 2010
                              • 860
                              '' For those who SEEK, .... they FIND ! Those who ASK,....RECEIVE And the door is OPENED for those who KNOCK."
