... to determine if the proper port is unblocked/open? Whether its port 21 for FTP, 139 or 445 for SMB, 25 or 587 for email, 9100 for printing, I can never be sure, just cause the function isn't working. Maybe a command prompt? An external utility? Or just admin rights to the main server? =^..^=
Is there a definitive test ...
blackcat: Master Of The Obvious =^..^=Tags: None -
Re: Is there a definitive test ...
So for example:
C:\Documents and Settings\user>telnet 192.168.0.100:139
or something like that? And what sort of response would I expect?If you'd like a serious answer to your request:
Ask and ye shall receive.
It's a free utility from Micro$oft.
Actually, I just used it again today.
Just run "portqueryui.exe". Nothing to install!Attached Files“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Thank you sir. I'll try it out tomorrow (time allowing).
You're a gentleman and a scholar. Thanks Ken. =^..^=Last edited by blackcat4866; 11-09-2012, 03:19 AM.If you'd like a serious answer to your request:
NetworkScan does this if properly configured:
SoftPerfect Network Scanner: fast and free network scanner
Go to Options>Program Options>Additional>Check for open TCP ports
Hans“Sent from my Intel 80286 using MS-DOS 2.0”
Hans
Thanks All. This will help a lot. =^..^=If you'd like a serious answer to your request:
HansIf you'd like a serious answer to your request:
I've used quite a few other tools, but I like the fact that it doesn't need to be installed. Quite handy if you need to run it on a customer's PC.“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
Like LPR Jar, it looks like it would run from the USB stick. =^..^=If you'd like a serious answer to your request:
On the pc you want to check (providing your on it) you can use: cmd, netsh firewall show state or netsh firewall show config (This works on XP)
This will will provide some useful info on what the firewall is blocking, although it may be different for win 7Networking skills are advantageous but use of a 3m vacuum cleaner is essentialComment
The filename and drive location you can change yourself.Comment
'' For those who SEEK, .... they FIND ! Those who ASK,....RECEIVE And the door is OPENED for those who KNOCK."Comment
