No A3 in Win7
  • madas
    • Aug 2008
    • 313
    No A3 in Win7
    Hi, is anyone aware of any settings in Win7 that stops a print driver from showing A3?
    our tech has tried updating the driver but it still does not show A3.
    all was well on thier XP setup
    driver is for a Kyocera Taskalfa 250ci. latest version on NZ/AU website
    We have never had this issue with any of our other customers with same driver/model/Win7
    any help welcome.
    cheers
    Les
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: No A3 in Win7
    Does this driver use SNMP to update its status? If it does you may have to enable SNMP under "Programs and Features" -> "Turn Windows features on or off" and/or enable SNMP Status under the driver port settings.
    • madas
      • Aug 2008
      • 313
      Re: No A3 in Win7
      Thanks Ruben, I will look into that, and if I find the cause I will post any fix.
      madas
        • 22999
        Re: No A3 in Win7
        What version of the driver are you using? The newest that I'm aware of is v 5.3.1025a5, and it does not list Win8 as a compatible operating system. The only driver fully compatible with Win8 is version 6.0.2212. =^..^=
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          Re: No A3 in Win7
          Here's a link to the 6.0.2212 driver: The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordable
          I just installed it in Windows 7 32 bit, and A3 appears to be no problem:
          • madas
            • Aug 2008
            • 313
            Re: No A3 in Win7
            Hi, thanks for replies. I have not been able to follow this up yet but I will post once sorted.
            It appears the driver installs ok and has been tested on another PC, but the option for A3 is missing on this particular computer. odd?
            I will need to talk to the tech for more info.
            madas
            • nmfaxman
              • 1702
              Re: No A3 in Win7
              Computer set for inch/ North American and not metric/ everywhere else?
              Just off the top of my head.
              • Redarmy
                • Sep 2011
                • 25
                Re: No A3 in Win7
                Enter your print server properties and check your forms tab, Check if you have A3 among that list.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: No A3 in Win7
                  You may be on to something there.
                  This would explain why only one PC has the issue.
                  I saw this happen once a long time ago with a Windows NT workstation.
                  Hmmmm....
