Windows 8 smb scanning
  • RRodgers
    • Jun 2009
    • 1947
    #46
    Re: Windows 8 smb scanning
    Originally posted by aiam
    i know, and you both right. i registered here but only activate my account yesterday because i lost my email login, and it was a pain to get the credentials back, sorry. i will try to help everytime possible. greetings and keep up the good work
    by the way if you want some firmwares, pm's or tutorials to macprint without ps,etc, just ask. this firmware i dont have and i really need help.
    How was it a pain?
    • sandmanmac
      • 3977
      #47
      Originally posted by faxman28
      New feature in win 8.1, go to control panel, programs and features, turn windows features on or off, there is SMB 1.0/CIFS Support check box. Don't know when this was added, found it on my win8.1 dell venue pro tablet and then checked my pc that has 8.1 pro on it and it is there also. also you can turn on FTP in windows under Internet Information services
      Just curious...I've seen this suggestion posted on a few different occasions.
      I've tried it with no success.
      Has anyone actually had luck with this, in lieu of a firmware update - specifically with Ricoh?
      • ApeosMan
        • Nov 2009
        • 183
        #48
        Originally posted by ruben
        The newer version of SMB in Windows 8/2012 should be backwards compatible with the SMB used by all copiers, the highest common version should be negotiated on connection. I say should be, because in practice so far it is not. However, I believe this may be due to a setting being missed in the newer version of Windows. I can only guess that share encryption is turned on by default or SMB is forced at a level too high; but as I do no have a copy of W8/2012 I cannot test these.
        A quick scan through Google shows some users having success with different brands by creating local user accounts.
        (Does Ricoh OS use SMBv1 or v2?)
        Backwards compatible unless the system administrator has switched off the backward compatiblity.
          • 37200
          #49
          The key words in ruben's post are "should be". Microsoft originally intended it to be fully backward compatible, but then included a required netbios security feature that was not compatible to most SMB scanning MFPs. There is a registry edit that would turned off the security feature. MFP manufacturers found it easier to modify network firmware to add support for the feature.
          • akewldewd
            • Dec 2012
            • 83
            #50
            Originally posted by sandmanmac
            I think I'd pay closer attention to the techs in this forum. I've personally used the custom firmware for Win8 on the C2500 and it works.
            Also:
            I had previously tried with/without passwords, etc., etc., as asked by 'drolfe' above. It would not work without firmware update
            Do you think it would work on an MP C3500 and if so can you send me links or attach firmware files to norm@copiersplusinc.com Thank you.
              • 37200
              #51
              If you are an authorized Ricoh technician, you can login to TSRC or rfg-esource and download the firmware. If you are an end user, contact your local Ricoh/Savin/Lanier dealer or branch and have a technician come out and update the firmware. The other option is to email Paul@JustManuals.com and ask for a price.
              • Andy21
                • 21
                #52
                Originally posted by Aquintasii
                MPC2000 Firmware is on its way.
                Hi Aquintasii,
                would you be so kind and send me Firmware for MP C3500/4500. I am registered on my-Ricoh.com but in Europe we can't get this firmware. Thank you for your help.
                • arahael
                  • Mar 2013
                  • 97
                  #53
                  You cannot use certain third-party devices to send a document to a shared folder in Windows RT 8.1, Windows 8.1, or Windows Server 2012 R2 Works perfect almost on all ricoh machines imo not only ricoh. You dont need special firmware
                  • Eric1968
                    • 2458
                    #54
                    Keep on dreaming...
                    • arahael
                      • Mar 2013
                      • 97
                      #55
                      It works on win 8.1 , win 8 I set by myself few times too . Regards Scan-to-SMB-problem-in-Win8.1-or-Server-2012-R2.pdf
                      • pereirataco
                        #56
                        Update all firmware
                        • halbrandenburg
                          Bypass Tray Expert
                          • Sep 2011
                          • 92
                          #57
                          Originally posted by pereirataco
                          Update all firmware
                          I agree - So far I've had 99% success with Ricoh devices when updating the firmware for SMB scanning. Politically, taking care of it on the Ricoh works out better than telling the customer to apply a patch to the server or workstation. In matters regarding scanning, it's almost always a copier issue.
                          Not blowing off the MS Tech Notes Arahael - If they work, great.
                          I've used FileZilla Server and scanned to FTP in some cases where it was another other unknown issue that prevents SMB scanning from going through.
                          • Andy21
                            • 21
                            #58
                            I did update for all firmware, but I don't have custom firmware for MP C3500/4500. I got custom firmware on our forum from @slimslob (here: http://www.copytechnet.com/forums/ri...ndows-8-a.html) for MP C2000/2500/3000 and it works. I know what to do, but I need this "FIRMWARE SPECIAL/CUSTOM".
                            Best Regards to all.
                            • Civ
                              #59
                              I run in that issue with a xerox colorqube 9303, updated the firmware and now it work perfectly.
                              • oteri
                                #60
                                Dear all,
                                i have windows 7 and aficio mp 2000
                                I dont have tech id, is it possible for you to send firmware to me by email.
                                Email:tecnostudio.info@gmail.com
                                Thanks in Advance
