Linux data capture from kyocera printer
  • madas
    • Aug 2008
    • 313
    Hi guys, can any one advise me on how to do a data capture on Linux so we can have it analyzed.
    I must admit this is not my best topic at all, but we need to try and sort out some issue with a customer.
    what i have read seems to indicate we some program to do it, is that correct?
    thanks for any help and sorry if i have left out any info you may need but if you let me
    know what else is required i will endevour to get it.
    madas
  • Eric1968
    • 2458
    Re: Linux data capture from kyocera printer
    Maybe you can try this :
      • 23009
      OK, I can't find it any more on KDA, but there is a small utility that runs on a CF card. Take a CF card and format it on the machine. Take it back to your PC card reader. Unzip the file I've attached and remove the outer folder so you just have a PRE folder with three files inside. Replace the existing PRE folder on the card with the resulting PRE folder that I'm attaching. Turn Off the MFP, insert the CF card, and power up. When booted up the utility will simultaneously print the job and store any docs to the API folder, until you run out of card space.
      Sorry I don't remember the name of the utility, but I have a copy of the resulting folder. It works on all Wisecore machines, and probably up to present.
      To everyone excepting madas: please don't send me private messages asking me to email you software.
      There is a funny story about this little utility:
      The FalconIII's had just come out and I was having some trouble setting up barcode fonts. My amazing tech rep showed up suggested I take a data capture. "Data capture? How?" I responded. After lots of looking we discover that the utility had not been released to the KDA website, but had been in circulation among the tech reps for quite a while. Then later that afternoon it magically appeared on KMA. =^..^=
      • madas
        • Aug 2008
        • 313
        thanks very much blackcat, i will see if i can do this next week.
        madas
          • 23009
          Two big questions:
          1) Does your printer still have a CF card slot?
          2) Is it Wisecore based?
          I probably can't help with either of those, but Good Luck! =^..^=
          • madas
            • Aug 2008
            • 313
            Two big questions:
            Hi Blackcat
            The model is a FS-C5300 which I believe is wisecore and has a CF slot on the main board.
            I have never done data capture so should be fun.
            madas
            • madas
              • Aug 2008
              • 313
              Hi, Thanks for the help. I found on the printers with a menu you go to service section, drum clean, test page etc, after you have put a usb stick in and "write data: appears in the menu, press ok twice and displays "data waiting", send your print job and it writes to the stick.
              this may not be the same on all the small printers or MFP's.
              thanks again
              madas
                • 23009
                That's good to know madas. Thanks. =^..^=
