Kyocera Fs-1128 Mfp - Scanning Issue.
  • duroo72
    • Nov 2009
    • 30
    Hi All,
    Anybody had this before on a Kyocera Fs-1128mfp where the user scans 4 pages to a folder on their pc in jpeg format all 4 pages come through , the first page is correct but the remaining 3 pages are blank?
    Thanks in advance.
    A+,Network+,Pdi+,Cdia+,MCSE,Konica Minolta Outward Associate
    • 23008
    Re: Kyocera Fs-1128 Mfp - Scanning Issue.
    ... but PDF and TIF formats scan OK? Maybe a memory upgrade will help here. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      try scanning as b/w and if it works that is a bug....I found a bug in the ta300 that was identical to that
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • mrsavin7
        • 11
        I know this isn't right replying like this, however since you are a Kyocera tech, are you able to scan to a 1128 via the USB connection? Must it be twain scanning?
        thanks, tva
        • Venom
          • Nov 2009
          • 765
          thanks, tva
          Yes only twain scanning if you use USB.
