LPR Capture
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    LPR Capture
    Does anyone have an app for LPR capture for print steam data??
    Mystic Crystal Revelations
  • Jomama46
    • 2900
    You dont really need an app, you can program a workstation to simulate a printer by first installing the LPR .
    If you want to do this without an app, I can send you the .pdf
    sigpic
    A+; Network +; PDI+
    • Tonerbomb
      • Feb 2005
      • 2589
      Please send it to me. tonerbomb@gmail.com. Thanks
      • unisys12
        • 489
        Also, you should have a copy of this on your laptop... News ...Remember that account I had that had blank areas when printing from a really old Novell Fax Server? This was the program I used to troubleshoot it. It does a ton of other things as well. Check out their home page and take a look around. One thing to note though is that the link above, Downloader 2006, contains most all the programs on the program page.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • Tonerbomb
          • Feb 2005
          • 2589
          Thanks Unisys but I already have this app. It doesn't like Vista business that I'm running on the laptop though. It crashes at start up something with msinet.ocx. I was told that another app called minilpr will work but I havn't found it yet.
          • unisys12
            • 489
            Originally posted by Tonerbomb
            ... I was told that another app called minilpr will work but I havn't found it yet.
            MINILPR seems to be a script that runs in a Linux enviroment. Although you have probably found the same info I did, but... it seems to be a fairly old script.
            Have you had any luck at performing what Jomama suggested or have you had a chance to try it yet?
            sigpic
              • 23008
              Maybe I'm not understanding exactly what you want...., but can't you print to file?
              • Tonerbomb
                • Feb 2005
                • 2589
                Unisys12 I got minilpr(minilpd) and miniraw. I have the same problem with vista, Raw capture works fine but the lpr capture won't run. I tried turning lpr monitoring on and off in Vista same result. They both run on XP, what a suprise.
                Blackcat4866 what I'm after is to capture the print stream to the printer so I can view it as text and see what commands are going to the printer with the job. IE not calling the correct font at a certain line or pulling from the wrong tray at the wrong time. Thanks to all for thier input!!!
                  • 23008
                  The print to file should do exactly that. When I am not working on a Copystar machine (which either have the data capture built in or can be added on a CF), the print to file will capture the exact text going to the printer.
                  As confirmation you can browse to the print-to-file and print the document via the Printable Data menu option on the web page or via a web based utility like KM-Net Viewer.
                  • unisys12
                    • 489
                    TB, I agree with blackcat here. It should do exactly what your wanting.
                    In this case though, just ask your customer to perform the operation (or walk them through it over the phone) and then you can save it to a jump drive or have them e-mail it to you. At that point, you should be able to take a look at the job from there.
                    I just did a test Print to File and it seems I cannot view it with any native programs on my home PC. I don't have Downloader `06 installed, so... let me see what I can dig up here...
                    (insert cricket noise here)
                    Here's one option to play with... not sure it supports Vista though - CodeProject: EMF Printer Spool File Viewer. Free source code and programming help
                    Might be helpful, but again since your using Vista... not sure - Viewing the output of a spool file
                    I also found, which you might already know this, that for print to file to work in Vista you have to open the printer properties and under the Ports tab choose File.
                    sigpic
                      • 23008
                      Textpad
                      Textpad works quite nicely to view your capture. You can get it for free here: TextPad - the text editor for Windows
                      the nice thing about textpad is that it can display hex & null characters that cannot be viewed in Notepad or Wordpad.
                      • Tonerbomb
                        • Feb 2005
                        • 2589
                        I've been using pclcodes for the text edits, works ok
                        Download PCLCodes 8.39 - Free Download Review at Shareware Connection Software Portal, No Crack Serial Number, No Key Warez
                        and mini lpd The MiniLPD and MiniRAW Page
                        Another problem with the print to file is that one job comes from a main frame so I need to capture at the printer. The other job comes from a citrix server through a win print server.Thanks !
                        • Tonerbomb
                          • Feb 2005
                          • 2589
                          I've finally got some capture working both on Vista and XP. Now trying to figure out the font commands is the next trick.
                          • unisys12
                            • 489
                            What format are the jobs in? (PCL, PS...) E-mail it to me and maybe I can help out... a little.
                            Oh yeah, don't forget about... http://www.tscweb.net/ref/pclpjl.asp
                            sigpic
                              • 23008
                              Same here. I've spent a bit of time decoding Post Script.
