km 2050
  • marley
    • Sep 2010
    • 58
    km 2050
    hello
    I have a kyocera km2050 connected as a scanner and printer .
    The printer all right, but the scanner sometimes loses the addresses of the destination pc ...
    DHCP is off .... any ideas ??
    • 23009
    Re: km 2050
    I'd like to clarify something first. Does the address book lose the IP address of the PC with the SMB folder ... , or does the address book retain the address but the PC has been assigned a new address by DHCP? If it's the latter case, you can either use the PC's host name (assuming DHCP can resolve it correctly), or you can set the PC to a static IP address. =^..^=
    • marley
      • Sep 2010
      • 58
      Re: km 2050
      Does the address book lose the IP address of the PC with scanner file utility
      IP addresses of static pc ( dhcp off)
