Problem in SMB Scanning in Window 8
  • Wind Cool
    • May 2014
    • 82
    Hi guys!
    Im facing SMB Scanning in Window 8 by setting Copier Ricoh MP2550 and MP2550B
    Any latest firmware to update on that model?
    Thanks !
  • Eric1968
    • 2458
    Re: Problem in SMB Scanning in Window 8
    Only on www.my-ricoh.com.
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      email Paul@justmanuals.com
      Mystic Crystal Revelations
        • 37502
        Originally posted by Tonerbomb
        Tonerbomb, it seems that every thread this person starts is a request for firmware. I've posted Paul's email address a couple of times.
        • Tonerbomb
          • Feb 2005
          • 2589
          Yeah he's a want want want poster. Haven't seen any give, give, give either....................
          • sandmanmac
            • 3981
            I've 'ignore listed' and 'red-carded' for those very reasons
            • Wind Cool
              • May 2014
              • 82
              The firmware from Paul actually i already purchase but not this Model of MP2550.
              Im a new user here and im not very sure about rules in here.
              Because previously i saw some user here are willing to share the firmware, so i try to ask.
              If i do any wrong, then im sorry about the thread i had post.
              Just want to ask you the meaning of "Give" is share the firmware with others or technical advice?
              • Eric1968
                • 2458
                There are a lot of new users here who ask for firmware on the first posts. If they have it, they won't come back. So the "unwritten" rule here is :
                Help someone out a few times and show that you're willing to contribute to this site. If all users see that you help to find a solution for someone else's problems, then you can expect something back.
                If you ask for firmware or service manuals in the first posts, chances are that you will be ignored.
                See this thread :
                http://www.copytechnet.com/forums/co...-scanning.html
                User Xuanthu wrote 3 posts and 3x times he's asking for firmware. That wont work here.
                • Wind Cool
                  • May 2014
                  • 82
                  See this thread :
                  I see.... thanks for advice, now i know the rules...
                  Yeap, i saw Xuanthu did ask but nobody reply.
                  • ApeosMan
                    • Nov 2009
                    • 183
                    Don't do this for the customer but advise them to update to Windows 8.1 (make sure they have system restore enabled or another type of system/data backup) as with Windows 8.1 has SMB v1 available. This can be enabled or disabled from Control Panel > Programs > Program Features.
                    From my understanding Windows 8 doesn't have SMB v1 backward compatibility.
                    • CorbinDallas
                      • Mar 2012
                      • 56
                      If they do not or cannot enable SMB v1 (like MAC OSX). You can use SMB over TCP by adding the port (445) to the destination and using the IP address instead of the name.
                      Example using SMB v1
                      \\mypc\scans
                      Example using SMB v2
                      \\10.0.0.25:445\scans
                      • CorbinDallas
                        • Mar 2012
                        • 56
                        Here is the link to Microsoft with instructions to activate and de-activate versions of SMB. Strongly recommend advising them, not performing this on your own.
                        How to enable and disable SMBv1, SMBv2, and SMBv3 in Windows Vista, Windows Server 2008, Windows 7, Windows Server 2008 R2, Windows 8, and Windows Server 2012
                        • Wind Cool
                          • May 2014
                          • 82
                          That one i never know before. Ok! I go and check thanks for the info.
