Email Setup
  • Madnhain
    • Dec 2012
    • 148
    Email Setup
    We are trying to send reports from an MFP on a schedule.
    We set up a generic gmail account for SMTP usage for these machines to use. The problem is that nearly all email providers require the use of SSL and the majority of these older MFPs don't support SSL resulting in the email reports not getting sent.
    Has anyone found a workaround for this?
    Thanks.
    • 37487
    Re: Email Setup
    Use Google's non-ssl SMTP server, aspmx.l.google.com. They can only send to another gmail account, but at least they can send and then forward to who they want from their gmail account. This works as long as their ISP does not block port 25 SMTP.
    • Madnhain
      • Dec 2012
      • 148
      Re: Email Setup
      Thank you for that option, however the service that I would need to forward the email to is a cloud based service that just receives the email and reports back the information.
      I don't have access to that email to verify it with gmail as a valid recipient of a forwarded email.
        • 37487
        Re: Email Setup
        Your other option is to set up an in house relay server such as stunnel.
        • ApeosMan
          • Nov 2009
          • 183
          Re: Email Setup
          Try creating an account with GMX.com I think they don't require any SSL/TLS.
          • wseyller
            • Sep 2012
            • 1129
            Best option I found is Inbox.com has a free mail account without SSL if you don't mind ads in the email. To remove ads only $8.88 per year.
            Sent from my DROID BIONIC using Tapatalk
            • emujo
              • Jun 2009
              • 3009
              Re: Email Setup
              I'm a little confused as to what you are trying to do...Do you want the MFP to send some kind of internal report (meter counts for example) on a schedule (which can be done) or some other type of email? Or are you just trying to use the MFP to send mail with a walk up user? The "on a schedule" part is what I don't quite understand. If you need SSL, or TLS and you are using anything older than about 4-5 years (KM products) then you are correct, these protocols are not supported. You certainly could scan back SMB, FTP or pull from the user boxes and forward via email as a workaround. Emujo
              • Madnhain
                • Dec 2012
                • 148
                Re: Email Setup
                I am setting up Sharp MFPs on a schedule to send copy counts as well as alert messages. These emails are handled by a cloud based sharp utility and our service department can review all machines at a glance.
                I have no problem setting up newer machines for this because newer machines have an option for SSL. Older machines do not. I tried to use google's non-ssl server but cannot verify the email address because the emails are sent to a cloud service and in order to forward an email using google, you have to verify that you own the receiving email address.
                The "on a schedule" thing is simply a monthly report sent on a particular schedule on the Sharp MFP, in this case it would be a copy count.
                I can set everything up just fine, and have on multiple machines, the issue is that older machines don't support SSL so I need some kind of workaround for these older machines to use modern SMTP settings.
                • sandmanmac
                  • 3981
                  Most web hosting companies offer an SSL and non-SSL mail server. When I'm dealing with a client that doesn't subscribe to a web hosting plan or to an ISP that does not offer a non-SSL solution, I simply use the server settings from a generic account I've set up with my web host.
                  I subscribed to a package entirely for this purpose. It's a great fallback when there are no other in house options, and it costs next to nothing
                  • Tonerbomb
                    AutoMajical Resolutionist
                    • Feb 2005
                    • 2589
                    Re: Email Setup
                    why not trying something like FM audit or pagetrac?????????????
                    Mystic Crystal Revelations
                    • tmaged
                      Owner/Service Manager
                      • Oct 2008
                      • 1885
                      Re: Email Setup
                      We had the same problem as we use Office365 & it doesn't allow unencrypted connections. I set up an account with Rackspace that uses our domain & accepts an unencrypted SMTP connection on 25, 587, 8025, or 2525.
                      It's $10 a month & we use it for scan to email for all of our customers that don't have their own exchange. It also allows you to enter the customers email as the senders email even though it's authenticating with your account. We tried GMX & some other free ones, but none were reliable. It's the best money we've spent as it saves a TON of headaches.
                      Hope that helps !
                      -Tony
                      www.dtios.com
                      Become a fan on Facebook
                      • bdcrandall13
                        • Sep 2010
                        • 236
                        Re: Email Setup
                        AOL does not require SSL. We have used an AOL account to send emails from old Sharps for years. The only bad thing is that the "reply-to" HAS to be the AOL address that you are using to authenticate with.
                        • Madnhain
                          • Dec 2012
                          • 148
                          Re: Email Setup
                          Thank you all for your input. I've got out IT manager looking into these options.
                          • ApeosMan
                            • Nov 2009
                            • 183
                            Re: Email Setup
                            If a customer uses Office365 and the MFP doesn't support SSL/TLS then use: mail.messaging.microsoft.com This is unauthenticated over port 25 with no SSL/TLS and the customer can only scan to email within their Office365 domain.
                            If a customer uses Gmail/Google apps and the MFP doesn't support SSL/TLS then use: aspmx.l.google.com This is unauthenticated over port 25 with no SSL/TLS and the customer can only scan to email back to their own gmail e-mail address used for sending or only scan within their google apps e-mail domain.
                              • 37487
                              Re: Email Setup
                              I have used Google's port 25 server for a few years. I didn't know about the Microsoft's port 25 server. My experience with Google's port 25 server is you can send to any email address within your Google apps domain or any other gmail account. The only draw back is if the ISP (such as AT&T), or the DSL modem (such as the NVG 510), blocks port 25.
                              I have also heard that Office365 will not work for MFPs that use SMTP over SSL. You have to be able to support TLS.
