A battery powered 5 port switch
  • JR2ALTA
    • Feb 2010
    • 2033
    I've been tapping into customers network to work right along side the machine a lot lately by using my 5 port switch. It's nice because often customers will want to print and scan while I am working. Assuming their not on a port-secured network that rejects uknown devices.
    That got me to thinking how nice a battery powered switch would be for troubleshooting. I know it would be completely inpractical and foolish to run an actual network balanced on the backs of a couple AA batteries, but for us it would be sweet not to have to find an outlet. Alas, there is no such thing out there.
    • 23010
    Re: A battery powered 5 port switch
    I agree it would be handy. I carry a switch with my laptop kit. =^..^=
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      I'd get a hub also so you could do packet captures if needed..................
      Mystic Crystal Revelations
        • 23010
        Now you've got me curious.
        This forum discusses the topic: Battery powered 4-5 port Network switch
        A switch like this draws only 1/2 amp at 9vdc: Rosewill RC-405X 10/100Mbps Switch - Newegg.com
        A 9v rectangular battery can supply 550mAH (milliamp hours), or approximately 500mA for 1 hour use, so it would be a poor choice for this job. Better: six "C" batteries in series can supply 6000mAH, or approximately 11 hours continuous use.
        The Linksys EZXS55W in my bag draws 700 milliamps at 7.5vdc
        So my Linksys would require five "C" batteries in series, and last approximately 8.5 hours.
        It's a simple retrofit to add a battery pack with the appropriate power plug. It seems manageable to me. This website offers what I would consider to be reasonable expectations of the standard, off-the-shelf batteries: Battery Capacity
        A "C" battery can support a continuous drain of 100mA (or 6 batteries: about 600mA).
        Here is the battery holder: 6 C Cell Battery Holder
        I'll have to create a "C" battery sized "filler" for my 5 cell pack. Perhaps a dead battery with a soldered bridge wire across it. All you need now the appropriate power connector. =^..^=
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          I've always carried an outlet "triple tap" so as to be assured some place to plug in either a hub or switch, not to mention my notebook.
          A power strip is a bad idea; they don't supply enough current, especially on larger machines.
          Then there are the customers that have the power filters that we sell. Not only do they protect the copier, but they provide 2 convenience outlets as well.
          • Hansoon
            • Sep 2007
            • 3402
            I always carry a miniature 3-port switch powered by the USB port of my laptop. Very convenient.
            Hans
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
              I know it's kinda rare, but some intelligent switches can detect an added switch or hub.
              I had that happen in a hospital a few years ago. Once their switch detected my 5 port hub, it shut the port down.
              Some customers strictly prohibit switches or hubs, so you have to be careful, and not just assume it's OK.
              • techsass
                • Dec 2010
                • 248
                I just got this USB switch off of Ebay. It's compact & the shipping from Hong Kong only took about 10 days - I didn't notice the location until it was too late.
                Tried to use it today for the 1st time & the client's network wasn't using DHCP.
                Fast Ethernet Network Switch Hub USB Cable Kable 5 Ports 10 100Mbps 2014 | eBay
                • MattL
                  • Apr 2012
                  • 97
                  If that was me I would not want any foreign devices to my network connecting. Anyone tried that with me and and that would be the contract terminated there and then.
                  • SargeNZ
                    • May 2012
                    • 263
                    The USB powered switch would be a good idea for those times when you need to access the web end of the copier but still allow their print jobs through. Usually with the clients permission I can get the Wifi password but of course this is not always available. I don't think anyone is suggesting that you just roll up and jam your laptop+switch into the network willy nilly.
                    • draph
                      • 132
                      I have to say this. All the posts to this topic were very useful and informative. That being said, if you read through them again, am I the only one who realizes what a technical GOD Blackcat is?
                      • drwevil
                        • Nov 2013
                        • 54
                        Just wondering, apart from doing a data capture, and then ONLY with their IT guys or gals permission.
                        Why you would connect your laptop to another companies network?
                        Your just asking for trouble .......
                        If they then get a virus or whatever ... even if it didn't come from your laptop it will be your fault as far as the customer is concerned.
                        alternatively if you pick something up from their network and infect your works network your IT guy will tear you a new but hole.
                        Where I use to work putting your laptop on someone else's network was pretty much a sackable offence... not quite but close....
                        I don't do it if I need to get my laptop on the net I hotspot my iPhone....
                        Great ideas for battery powering a switch or hub..
                        • frodo
                          • Aug 2009
                          • 36
                          Excellent, Just bought 3 of these for my techs.
                          $10.63 and free postage and had Aus Stock aswell
                          Thanks.
                          • CWP
                            • Jun 2013
                            • 168
                            USB powered with ethernet pass-through and wireless capabilities. You shouldn't need anything else except maybe a USB battery pack if you can't power from the device.
                            And it is not expensive.
                            Amazon.com: ZyXEL 3-in-1 Wireless N Pocket Travel Router, Access Point, and Ethernet Client (MWR102): Computers & Accessories
                            • speedtek
                              • Apr 2013
                              • 46
                              After seeing this thread I went ahead and bought a USB-powered switch on eBay, and 2 days later another tech showed me his method:
                              Use a USB-to-ethernet dongle and just bridge the connection to your on-board ethernet. Takes up much less room!
