Scan To Desktop Ricoh C3300
  • jimmyd
    • Jul 2025
    Ricoh C3300
    Connected as a local printer to a work station running Windows 8. There really is not a network configuration/connection just a bunch of
    workstations connected to a USB hub connected to the Ricoh C3300. All connected to internet through the same hub.
    Is it possible to scan to a file folder on the desktop of the PC that is directly connected (via printer cable and through USB Hub) to the Ricoh C3300.
    Connecting the printer via the printer cable the printing was plug and play and it setup automatically.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Scan To Desktop Ricoh C3300
    Originally posted by jimmyd
    Ricoh C3300
    Scanning is done through ethernet only. If you want to scan to Windows 8 you will need to do FTP scanning or update the Network Support firmware to 8.33 and System/Copy to 2.01 or greater.
    No we won't give you the firmware, you have to be a Ricoh qualified engineer.
      • 37483
      Ricoh C3300
      Are you talking about a true USB hub where all the computers connect to the hub via USB or are you talking about a network switch/router with a USB printer port? I am figuring it is through a network router as I have never heard of a true USB hub that connects to the internet and if it did, connection would be rather crappy. If that is the case and you are using the USB printer port on the router because you do not have a free network port, spend $20 and get a 5 port work-group switch.
      Plug and play configuration of the printer uses Microsoft's PCL driver which is not that good.
      • anothertech
        • 1768
        Yes connect it via ethernet, it is very easy. To get it scanning, don't you have an old Windows XP box laying around? You could through that on the network for a scan server, provided they are not to concerned with security, as Win XP is no longer patched/updated.
