Need technicians help to connect external device to defirents copiers
  • mkdirs
    • Oct 2014
    • 177
    Hello guys
    i develop an external device PayStation unit to manage copiers
    i am a Xerox technician so i know how and where to connect my
    external
    device.
    it's a standard protocol (I/O) for all copiers
    i need help from other brands technicians like KYOCERA and Ricoh and MINOLTA.
    to help me Ex. where the plug located for the uber brandes and how to configure in the machine (Like Key Counter) or External Device Unit
    i test the device with old ricoh copiers 2205 the device work fantastic
    also i test it with B&W AND Color Xerox copiers and its work fine
    in new ricoh copiers like mp3352 i cannot fined the connector
    right now i have kyocera 5501i for test any kyocera tech can help to give me an instruction how and where the key counter located and how to confgure it !!
    also
    MINOLTA and other brands !!
    for more information i upload to youtube how the device work
    YouTube
    thanks all
    Xerotk.com
    xerox copier technician
    • 27454
    Re: Need technicians help to connect external device to defirents copiers
    Older Kyocera use a wired plug to connect.New machine it plugs direct to main pcb.
    Your 5501i will need a connect plug.
    You have to turn on key counter in maintenance mode thats the same on all models.
    Older models the connection jumper plug is usally on the side near the rear of machine.
    If need you can pm me for the correct sim mode
    • mkdirs
      • Oct 2014
      • 177
      thanks to
      bsm2
      he give me the Kyocera answer
      konica Minolta techs !!! any one here ???
      and what about recoh !!!
      Xerotk.com
      • Synthohol
        Certified Konica Expert
        • 5463
        the 4 wire "molex" connector is behind the grill above the RS door on konicas.
        the newer series also offer a connector on the PRCB for other types of payment solution hardware.
        they both use different selections in vendor mode. trial and error unless your hardware specifies which one to use.
        • copier tech
          • 7934
          Originally posted by mkdirs
          Hello guys
          external
          device.
          also
          YouTube
          thanks all
          For Ricoh you need an optional board see attached this is for the MP 3352
          Optional Counter Interface type A.pdf
