Hello, I recently picked up a canon pc 425 copier and it all works fine, but I'm actually interested in intentionally messing up the print quality for artwork. So my question is, what are some things I can do to intentionally mess up the print quality without totally ruining the copier itself? Things like faint print, blotchy printing, etc. I quite like the look of faint print, and the copier does actually have a dial that changes the lightness of the print which I find can be useful, but I also find it looses too much fine detail when doing that. I'm not too terribly knowledgeable about this kind of thing so hopefully this is the right place to ask. I'm open to all kinds of suggestions for this probably somewhat weird question, Thanks!
General question regarding intentionally poor print quality.
Re: General question regarding intentionally poor print quality.
If your Canon is mono-compunent, and I suspect it is, you could make some fingerprints on the developing cylinder. Mono-component machines will do something called "mottling" when the toner is contaminated with finger oil. When you've had enough mottling, you can just dry-wipe the developing cylinder.
I can't say as I've ever had anyone ask intentionally for bad copies. ?? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Hello, I recently picked up a canon pc 425 copier and it all works fine, but I'm actually interested in intentionally messing up the print quality for artwork. So my question is, what are some things I can do to intentionally mess up the print quality without totally ruining the copier itself? Things like faint print, blotchy printing, etc. I quite like the look of faint print, and the copier does actually have a dial that changes the lightness of the print which I find can be useful, but I also find it looses too much fine detail when doing that. I'm not too terribly knowledgeable about this kind of thing so hopefully this is the right place to ask. I'm open to all kinds of suggestions for this probably somewhat weird question, Thanks!Let us eat, drink, and be merry, because tomorrow we may die!
Smear some vaseline on the lens.Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
“I think you should treat good friends like a fine wine. That’s why I keep mine locked up in the basement.” - Tim HawkinsComment
I can't say as I've ever had anyone ask intentionally for bad copies. ?? =^..^=Comment
I haven't seen one of these in a very long time ... but when you remove the toner cartridge you should see the developing roller with an even coating of toner on it. The drum will be clean. Anybody remember better than me? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Thanks for the replies guys, definitely some fun suggestions. I also might try refilling an old empty cartridge the copier came with to see if any possible mechanical wear will create interesting texture. Though probably not as much as directly messing with the components I would assume. Perhaps mixing techniques?Comment
Wrong toner would definitely be interesting ... but messy, and hard to clean up after.If you'd like a serious answer to your request:
I have a couple of customers that I can send your way....they can F anything up.Adversity temporarily visits a strong man but stays with the weak for a lifetime.Comment
