ir3570 persistent jam on PS10
  • Guest
    #16
    Re: ir3570 persistent jam on PS10
    My IR 3045 Do the same
    the Paper stops in the middle of the fixing unit. when i removed the paper it is folded like an accordion.
    I tried all 4 trays and did the same thing
    Paper Orientation: Portait
    I did notice that when i place the paper in Landscape it works much better but will jam after couple of copies and some of the copies have fold in the middle. so it goes out of the machine shorter than other copies.
    Error: 1017, 0202, 0102, 0201
    All sensors checked, - not sticking
    right door flapper check
    Fixing unit rolls fine
    Paper: SUB20/70gsm
    • copier tech
      • 8100
      #17
      Ok, does the machine have a Genuine Canon Fixing Film Assy fitted?
      • Guest
        #18
        i got my issue fixed by cleaning the solenoid:
        There's a worn foam that turns sticky and delays paper out.
        • doc1479
          • May 2015
          • 8
          #19
          Well, as it turned out, it was registration actuator related after all.
          I have put new one in, but that by itself wasn't enough, I had to bend bracket a bit to bring it forward and it went through without a hitch after that. Both A4 and A4R ran fine on single or duplex.
          Thanks guys for your help !
          • Guest
            #20
            any instructions on how to change the Ps9 or pre registration sensor?
            • copier tech
              • 8100
              #21
              If you take out the top feed unit you can gain access from underneath
              • mpj
                #22
                Originally posted by doc1479
                Hi everybody,
                I hope somebody can help me here, as I'm running out of ideas.
                I have an issue on ir3570. It constantly jams 0101 on ps10, either stationary or delay.
                Paper is always stuck half way through the fuser.
                Unit already got gray vertical path rollers (FB6-4852) and upgraded lower door assy (FM3-1296).
                I've put new registration sensors (FL2-6580) and swapped pickup assemblies around. I've also removed dumper on ps9 and cleaned the sensors. Same story.
                It prints/copies fine from manual feed, so I've ruled out any fuser related issues.
                It has old style preregistration flag, no metal jacket, but hardly any wear (15mm), so I don't think it needs a replace.
                Any thoughts ?
                Thanks,
                John
                hi john
                remove the black sponges on the paper deliver guide on the right door.when they get old the guide stucks all the time.
                • sa0001jan
                  #23
                  where is ps9 sensor in canon machine please tell me
                  • copier tech
                    • 8100
                    #24
                    Re: where is ps9 sensor in canon machine please tell me
                    Refer to the parts/service manual
