canon ir 4570 peoblem
  • sultonul arifin
    • Jun 2015
    • 7
    my canon ir 4570 have a horisontal line, what happened with my canon ir 4570 ?
  • aandy_py
    • Aug 2015
    • 15
    Re: canon ir 4570 peoblem
    I would suggest you have a drum earth problem, either with the coating or earth tab in the drum.
    • SESHU
      • 163
      Change the Drum or Charging roller.
      • Canuck
        Tech Specialist
        • 1713
        LTR or LTRR?
        • techstar
          • Aug 2015
          • 7
          I agree change your Drum, cleaner and charge roller if possible
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            This is copy sample! How's print quality?
              • 23009
              If that interval is 95.5mm you've got a drum ground issue. All the solutions include replacing the drum unit.
              Possible causes:
              Normal wear of the drum coating. Any place where the coating is worn through to the aluminum core, you'll get drum ground bars.
              Loss of drum ground. You can measure the resistance from the aluminum edge of the drum cylinder to the frame ground. It should be very close to zero ohms. I've seen the copper contact in the rear drum cap start to arc, and burn up the copper contact.
              • sultonul arifin
                • Jun 2015
                • 7
                a drum just been replaced, approximately 5000 sheets
                • sultonul arifin
                  • Jun 2015
                  • 7
                  Originally posted by Canuck
                  LTR or LTRR?
                  LTLR/LGL
                  • sultonul arifin
                    • Jun 2015
                    • 7
                    print quality is still good
                    • copier tech
                      • 8176
                      You say you replaced the drum, was this a genuine Canon Drum Unit or just a drum kit etc?
                      • Canuck
                        Tech Specialist
                        • 1713
                        If only does it on copying and not printing(as you state), you have a reader issue. Cable to CIS could have breaks in it...
                        • sultonul arifin
                          • Jun 2015
                          • 7
                          i replaced like this
                          • Canuck
                            Tech Specialist
                            • 1713
                            I REPEAT>>>IF PRINTS ARE GOOD AND ONLY HAPPENS ON COPIES,IT IS A READER ISSUE. This isn't rocket science. Stop guessing and start troubleshooting. Prints are good....why would you suspect the drum? I'm done with this thread
                            • copier tech
                              • 8176
                              You only replaced the drum, you need to fit a new drum unit, the compatible parts cause so many problems!
