Smudge printouts from Canon iR Adv C5030
  • icopier
    • Apr 2011
    • 45
    [CQ] Smudge printouts from Canon iR Adv C5030
    Hi guys,
    Need advice from you guys.
    Printout was fine and nice when tested in factory, but when shifted to customer premises,the prints smudge (pics attached).
    Done:
    1. Change all all drums and developer (no help)
    2. Change to another ITB (with cleaner), similar issue.
    3. Clean laser glass sensor (same)
    Anyone encountered the same issue or is there any other issue that may cause this?
    What issues could improper shifting cause?
    Attached PG 6 and 10 for your kind reference.
    Thanks all in advance!
  • alex@wocltd.com
    • 430
    Re: Smudge printouts from Canon iR Adv C5030
    its the mylar strip on the atr sensor array......peel it off and good to go......
    • mramlawi
      • Jul 2011
      • 838
      Looks like its a heater problem also clean they itb belt blade and try to stop it before entering the fusing unit.
      Distinguished road makes you jewel in rough
      • copier tech
        • 8192
        Do another pg10 test but stop the machine & check the image on the ITB if it looks smudged you can rule out the fuser, no smudge you can rule out the itb & drums etc.
        As has been sugested a mayar guide could be the cause, check the paper path, could even be a piece of paper trapped
