IR400 E220 error code
  • ldfrepairs
    • Oct 2012
    • 148
    Replaced fluorescent lamp but error is still displayed. Any other sugestion to correct error?
    drugstore-onlinecatalog.com
  • teckat
    • 16083
    Re: IR400 E220 error code
    Check that the Ribbon Cable between the CCD Unit and the Image Processor Board is not pinched.
      • 23010
      There's an oldie that I still have records on:
      E220 after the start key is pressed, when in warmup. Also E100 after the start key is pressed, when warmup is completed. Defective CCD unit assembly. Replace the CCD & CCD PCB Assembly (FG6-3864-000).
      E220, E301, protection jam 0400 at the registration roller. Blackened scan lamp ends. Replace scan lamp (FH7-3314-000).
      E220. The scan lamp heater may have slipped around and is partially blocking the lamp intensity sensor. Reposition the lamp heater.
      E220. The scan lamp does not turn ON, but checks good. Check fuse 301 & fuse 302 on the CCD unit. If either fuse is open, replace the CCD unit (FG6-3864-000)
      • copier tech
        • 8200
        I remember changing a few CCD's on this model for E220 when I worked on them some time ago!
        You won't be able to buy them new anymore, your only hope is to buy or find a scrap machine to remove it from.
